what do u think of the b44
I can't comment on a XX4 because I never owned one and have yet to even see one up close. The XXX4 was made of egg shells and stayed broken all the time. I am not biased and would like to see your XX4 compared to the B44....one huge minus will be belt driven. I can't stand belt drive and will not own another one. Losi will need to go with what wins and copy the shaft driven ones before I will be interested.
I thought it was the driver that won the race. losi just needs to take the jrxs and make a wheeler out of it if you ask me. I dont think you can go wwrong with either really but as of right now the B44 will be a better car for you than the XXX4. Make sure you attach the servo to the mounts before you put them in the car. I had to help somebody attach a servo without taking the mounts off because an allen wrench broke off in one and the other screw was stripped.
XX4- Tranny is not the greatest, super durable car though
XXX4-decent tranny, breaks very easily though, I have one and it is not very good, I would say to stay away from it
B44- very good shaft drive tranny, durable, lots of carbon fiber
You may want to check out the kyosho lazer zx5 and the academy sbv2, from what i have seen they are pretty good too.
#21
I would be concerned with parts availability for the XX4 - especially given the fact that it is a re-release. I am betting that as soon as Losi comes out with a replacement for the XXX4 the XX4 parts production will grind to a halt.
There is stuff now that you can no longer get for the XXX4 so my feeling would be that if you are spending that kind of money on a car, go current so you know you won't have parts issues down the road.
#22
The XX4 parts are already being discontiued you will no longer be able to get a chassis from what I heard. The B44 seems nice but I like the simplicity of my V2 and the fact that I can run my lipo sticks. The entire advantage as I see it to saddle packs is to get all that weight over the rear and since I won't be running nimh anymore i see the mid motor as a downfall to the B44.
#23
Tech Prophet
XX4 parts are going to be very hard to get soon. The molds for this car are all shot from what I have been hearing and they are not going to redo the tooling. It was/is a great car and maybe the best 4wd ever made but I would not get one right now due to parts avaiability. The ZX-5 takes stick/lipo packs as well. The new SP should be out in a couple weeks.
#25
This should be a little better than an estimate.
http://www.speedtechrc.com/store/ebp...nid=52&id=6972
#26
Pos Name Nation Points Leg 1 Leg 2 Leg 3 Chassis
1 JARED TEBO USA 20 10 10 0 B44
2 RYAN MAIFIELD USA 19 9 4 10 B44
3 RYAN CAVALIERI USA 18 8 9 9 B44
4 MASAMI HIROSAKA JAPAN 15 6 8 7 Yokomo
5 BILLY EASTON USA 12 5 7 3 Serpent
6 ATSUSHI HARA JAPAN 12 7 5 2 HB D4
7 RICK HOHWART USA 12 2 6 6 B44
8 HAYATO MATSUZAKI JAPAN 11 1 3 8 HB D4
9 NAOTO MATSUKURA JAPAN 8 3 2 5 Yokomo
10 JORN NEUMANN GERMANY 8 4 1 4 Serpent
I don't see a V2 or even a Losi in the top 10, but there was 4 of the limited number of B44s in the main with 3 on top!
Pictures are worth a thousand words!
#28
These guys downfall was with a mid motor buggy!
Try and read closely before you go getting defensive.
#30
What's wrong with li-po saddle packs???
I am going to use 5500 mah MaxAmp ones!!!
