Returning to R/C, new to TC's, need advise.
Look for a TC3, TC4 or XXX-S. The XXX-S is belted, but the drive line is completely enclosed and IMO probably the best choice.
#20
Blind skwerl, The guys are giving good advice. I run out front on the street as well, my son inlaw, and step daughter, all have TC3's we have a ball, very durable, but parts are getting a little sparse. I bought up alot of used equipment on here, so we should be good for a while..If you go Tc4 route you should be golden, I also run a TA05 which is a great car, but have had a couple of belts/pulleys destruct due to stones...
I just put together a Corally RDX and have about ten packs through her with no signs of belt troubles, it has a more substantial set of belts compared to the Tamiya, and the chasis will also let stones fall through easier.Thats something to consider.. Similar to the X-Rays in belt/chasis design. You would probably appreciate a carbon fibre dual plate chasis (there are alot of them Mi3 rdx xray TRF 415 etc.) for the tech factor. They also run quiet and smooth. The RDX is like butter
If you where here about a month ago people were selling tc's left and right I guess they were upgrading for carpet season. If you hold out something will come up. We have a great For sale forum with a good feedback system...
#24
LMAO at the people recommending A Corally Phi for street "bashing"... can I have some of your money?
#25
On the AE website internet specials you can get the FT TC4 for $189.99 and the RTR for $159.99
http://www.rc10.com/misc/internet_specials.htm
#27
I don't think anyone has suggested this yet and it's not exactly a touring car but maybe an AE 18r would be good for your purposes. Its cheap, durable, and can be made fast easily. Best of all it's a rally car so you can take it off small jumps without hurting it. Parts are cheap and can be found anywhere as well! Also its small so you can run it indoors better than a 1/10 tc.
#29
OK, an Associated Factory Team TC4 is on the way. Now I have to figure out motor and ESC. I am going to be using a high powered setup, but want to start off with something a bit more tame until I get comfortable with it again. The mamba systems are adjustable through your pc; can you "de-tune" the settings to make them milder to begin with? Or should I be looking elsewhere?
P.S. - slakr, thanks for the info. A friend and I both bought new FT TC4's from Associated. Always loved their cars.
#30
yes i think you can, if not just set the throttle endpoints down to about 50% until you get the hang of things. then crank it up and away you go!
