New piston/sleeve.
New piston/sleeve.
Ok, this is my first time actually buying just the piston and sleeve for my AE .15 Engine, and in the little package it comes with the piston inside the sleeve, although it is really tight because, of course, it isn't broken in. I have to install a conrad in it, and i don't know if I need to take the piston out to put the conrad in, because I'm scared to push it out because of scratching either the piston or sleeve. Any suggestions??
Unless you can perform magic, you will have to take the piston out, from the bottom. Use a soft wood dowel or plastic stick like the end of a tooth brush, but it should not be jammed in that hard unless someone forced it in the sleeve. Make sure you don't damage the piston pin clip when you take it out and check your conrod to crank bushing for wear at TDC. Also make sure your bearings are good, or you will trash that new P/S set.
In order to remove the conrod, you'll need a needle point tweezer to remove the G spot.. oppss.. sorry, I mean the G clip (little bar) be careful, because the clip might fly away that you might lost it.
A little trick that I learned with the blasted g-clip. Get a plastic bag of some flavor. (I used the one my piston/sleeve came in) Stick the piston and rod in it and then use the needle nose pliers or something like that to take it off. If it jumps, it'll stay in the bag and you don't lose the clip then.
Alright, instead of making another post of a new piston/sleeve, I'm going to put another question here..
I have this .12 Drake platinum edition engine, with no piston/sleeve because, well you guessed it, it's worn out. No biggie. But for some odd reason Trinity doesn't carry a new piston/sleeve for it, so I'm looking for another company that will fit in this engine. I've asked O.S. and they said they haven't tested it before, so they have no idea..
Anyone help??
Anyone help??
Anyone help??
Anyone help??
All that and a bag of chips for 25 bucks.
I would suggest replacing the wrist pin clip on the exhaust side at least, it gets a lot of heat on that side and can be brittle from removal and reinstall, would hate to see it fail/break and go through the engine ruining a brand new piston/sleeve. The clips are cheap...
