Cleaning exhaust pipes
Spray on oven cleaner and some elbow grease. I didn't have an over to throw it in but I let it soak a couple times and scrubbed it with a wire brush. I think if you have an old oven to put it in, it would probably look good as new. After using the oven cleaner, I used some automotive aluminum polish to shine it up a little and it looked pretty good.
DRANO, just don't leave it in there for too long.
I once forgot a pipe in that was soaked in Drano for 4 weeks, not much left
simming in good quality radiator coolant overnight it will take everything off.
haven't tryed anti freeze...have to give it a shot....
pipe cleaning
The best way I've found is that after each run if possible use some fuel to clean the pipe preventing varnish and tire buildup. That being said I use CARB and CHOKE cleaner sold in the 1 galon tin, it stinks so just throw the pipes in and leave it,prefferebly outside a couple days.
I have also heard simple green for a day or so in a crock pot works too.
Thanks for all the suggestions.
I ended up trying the Carbon-Off from Smart and Final and this stuff really works. I spayed it on and let it sit for 15 min and rinsed with water and it pulled the carbon build up right off.
For the stubborn areas, it says use a scotch pad.
http://www.discoveryproducts.com/index_carbon_off.html
Wonder what the same product in Oz would be
