Soaking belts??
Originally posted by fatdoggy
If you can't feel a noticable difference then don't worry, but if you feel a difference then change them. If you floor it from a stand still what happens, do you hear the sound?
one more thing is it true that it can ware out faster when you soak your belts?
that tire compound idea is genius i might try it out
too loose??
if the belt becomes to loose,
run the belt in wet, detergent soap!!!
it will tighten up!!!! just run the top portion of the belt, the one without teeth!!
got the idea from using it in real cars and it works in RC's tooo!!
