Choking Problem! Help
When I push the throttle around 30%~50% and turn the steering to the left and hold, my quantum competition choke. The SET red light is unstable turn on and off. What can cause the problem?
what do you mean by choke?
Feels like the interfere with esc.
thats your motor, check to see if you have all the caps and diodes on the motor. It might also be he reciver, try moving it around in diffrent places or to peices of tape.
do you have a graphite chassis?
Put on 3 caps and see if that fixes the problem.
caps make a big diffrence, I never trust the built in ones
Here's the pic. Should I move esc away from receiver bit more?
yes and keep the arial away from all other electical things
1 other thing dont leave your battery pluged in can hurt your speedy
I solder the caps to motor and remove the power cap. The problem still not fixed.
