Best way 2 make a Homemade Discharger? >
Old 10-20-2007, 09:14 AM
jono mad racer's Avatar
Default Best way 2 make a Homemade Discharger?
Hey,
Wats the best way to make a homemade discharger?
Wat blubs are the best to do it with?
Share some pics and ideas pls
Cheers,
JONo
jono mad racer is offline
Old 10-20-2007, 03:44 PM
ray3619's Avatar
might think about picking it up used , pretty good deals with people going lipo, ray
ray3619 is offline
Old 10-20-2007, 04:45 PM
FOXY923's Avatar
I used this article
FOXY923 is offline
Old 10-20-2007, 05:39 PM
Johnathan's Avatar
you can get 4 - 1ohm 10w resistors from radioshack, and hook them up in parralel. it will have a discharge current of about 20-30 amps depending on your battery. have some sort of a way to cool it down, or at least something none-flamable to set it on, as it gets VERY hot.
or you could hook up a gazilion lightbulbs ( tailight ones ) in series, and get 5-10 amps discharge. if you go with bulbs, get sunglasses!
cheers!
Johnathan is offline
Old 10-20-2007, 06:10 PM
alexb2000's Avatar
The bulbs you need are 1157's I believe, 10 bubls give you 20 amps of discharge.
alexb2000 is offline
Old 10-21-2007, 09:36 AM
joe of loath's Avatar
12 volt 50w ceiling lamps. 5 gives 20 amp discharge. (roughly. we have a test rig for capacity checking car batteries that uses a set of these) you have to have a volt meter attatched to stop when the batteries reach 1 volt or whatever. (any lower and the accuracy of the thing means you risk killing the cells)
joe of loath is offline
Old 10-21-2007, 12:02 PM
*Chrominator*'s Avatar
Trader Rating: 19 (100%+)
If you build one , make sure you buy a voltage cut off switch, or you will dead short your battery's . when I first built mine, I didn't know about the cut off and I killed a brand new battery .
I also have two Integy equalizing trays for sale in the for sale forums.
Check it out , http://www.rctech.net/forum/showthread.php?t=183840
If you were to buy one or both of the equalizer trays, I would throw in
the light bulb discharger with cut-off switch for Free .
PM me if your interested.
Thanks Mike.
*Chrominator* is offline
Old 10-21-2007, 02:39 PM
FOXY923's Avatar
See a cut off switch here
FOXY923 is offline
Old 10-21-2007, 03:05 PM
That's it ! Its even got my initials on it, MPH .
Old 10-21-2007, 03:21 PM
mafiaracers's Avatar
Trader Rating: 22 (100%+)
10 #1157 brake light bulbs strung together is 20amps, a cutoff is nice to have, but eyeballing the lights when they get dim is good enough usually
mafiaracers is offline
Old 10-23-2007, 02:46 PM
you have cool initials! you can tell your freinds you have a monogrammed speedometer in your car!
Old 10-23-2007, 02:58 PM
Originally Posted by joe of loath
you have cool initials! you can tell your Friends you have a monogrammed speedometer in your car!
Ha Ha That's a good one , I will have to remember that one.
I guess I was born for SPEED
Old 10-23-2007, 03:01 PM
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Yup thats what I used. I had 15 in an aluminum enclosure with open ends.
BillyCaldwell is offline
