MBX5 is here!!!!
#391
Originally posted by sturla
Hi
Where is the cheapest place to order a mbx5? Any hop ups that is needed right away?
Hi
#392
Originally posted by e420x
I am an old MBX4 racer..thinking bout getting back into it. I am going for a MBX 5...which is the Novcarossi engine to get now..I think I used to run a 5 port Noa with an 086 pipe. What is the setup now? Going to run Futaba servos so I need to also know which is a good steering and good throttle servo.
For futaba servos.. (good choice) grab an S9350 for steering, and throttle depends on what you want to spend. I've got an S9451 there, but you could go for something much cheaper and it'd be fine.
#393
wassup moogen racers
Hey racers,
just picked up an mbx 5 just wanted to ask for tips on building it,
what's a good basic set up for shocks, diffs, etc., and brake bias.(how much for the rears and the fronts)
any help would be greatly appreciated.
I was debating whether to get the k3 or the mbx 5. While do some research i feel comfortable going with the mugen mbx 5.
thanks racers.
aloha
thanks racers.
aloha
#395
oh yeah i forgot to mention that
our track is pretty tight, with hard packed and loose dirt on the top, and there is several corners which is pretty loomy and rutty.
thanks again.
thanks again.
#396
thanks again.
thanks again.
#397
thank you very much
thanks for the info
aloha and mahalo
aloha and mahalo
#398
#399
brake bias
can anyone give any info on the brake bias on the mbx 5
what do you folks use
is there more brakes on the front than the rears
is there more brakes on the rears than the fronts
or do you folks folks run 50/50 brake bias.
any info would be appreciated.
thanks.
thanks.
#400
most people have it set with more rear brake than front
i want a mbx5 prospec now
#401
...just get those Mugen optional parts, dude.
I,on the other hand, bought Ratzas parts and have been happy with the performance and durability of the car .
#402
I see only 5-6 option parts that are really needed. I like the Stifer Motor Mount
#403
what's the difference between the ratzas and the mugen optional parts. which is cheaper
i bent the mugen optional front shock tower.
i'll have to use the stock front shock tower for now.
#404
I have a question to any of u Mugen guys. For some reason my MBX-5 doesn't have a tight turn radius that i like unless i use alot of brakes. How do i get more high speed steering? becuz i like to throw it into the corners without pushing?
