MBX5 is here!!!!
#361
I would suggest keeping the car until you are ready to make the move.. do some research in that time of the model that suits you... keep in mind parts availability and other local drivers cars... it's easier to get going with a few tips from a fellow driver of your car and if you break in an emergency they may let you bum a part
#362
Thanks, thats good advise.
REMEMBER, ITS NOT HOW HARD YOU HIT THE WALL, ITS HOW FAR YOU MOVE IT.....
#363
#364
got an mbx5 recently, and i think everythink is stock, escept for the diff oils, the diff oils are 5K-7K-1K, front to rear... how can i get more on power steering? would removing the sway bars help?
#366
I run 5 10 2 with stock sway bars. stock pistons 350F/300R
#367
I would get the 1100mah nimh packs (the ones for $21.99) as nimh is a superior battery technology, and one advantage is that the memory effect that used to plague the old nicads is greatly reduced. So topping up isn't as much of a sin, and ensures your battery is always full of juice.
It would be nice if you could get the nimh's in a higher mah rating, 1200 would be nice, but 1100 should be fine.
-uDi
-uDi
#369
http://www2.towerhobbies.com/cgi-bin...&I=LXVG17&P=ML
charge it with this at .5 amps...if you are in a hurry 1 amp max.
http://www2.towerhobbies.com/cgi-bin...&I=LXAVN1&P=ML
nickel metalhydride gives you more run time than nicads......be sure to get a charger (like what I suggested) that charges nickel metalhydride.......do not discharge.....unlike nicads....discharge is a must.
#370
for reciever batts, I assemble my own pack .
6 AA 2000mah nickel metalhydride ..it fits the X5 perfectly.
#371
how about the throttle servo? metal gear or nylon gear?
#374
Originally posted by penggoy
6 AA? Can you pls post pic so I can see how you did it? Im using this charger
X
XX
XX
...hope you understand.
