alternate clutch for 8ight-t
I had the same issue as you until I replaced my crappy losi clutch with the werks clutch. My buddy has both the 8 and 8T and he's happy with the losi clutch on the buggy, but the combo of heavier truck with heavier springs kills the clutch shoes and smokes the bearings quickly. BTW I needed to fashion a crankshaft extender to use the stock clutch bell with the standard engine mounts. IF you'd like to use a standard OFNA/mugen type of bell you'll need to move the engine forward a few mm, which is only possible with the King Headz engine mount.
you can also do the same thing with the new losi quick change mount.
carolinasrc.com get the contact number and talk with greg he sell m2c clutch system where u can use the standard clutch bell. that clutch is actually a tad bit better then the losi and the bearings will last a little better. The main reason for losi tearing the bearings up is the chassis flexi's a little to much wish is one reason y the car and truck turn so well... good luck
fioroni turbo clutch (mugen/losi version flywheel). shoes last forever, i mean really forever, and bearings also. use it with the original losi bell and it fit perfect. just replace the losi collet with a standrad one.
I can't be happier with my Losi clutch's, I replace bearings about as often as with other 3 shoe clutches. But the shoes last 10 times longer than 3 shoe aluminum clutches. I would rather buy $1 bearings than $20-$25 shoes.
By the way use A-main 10 pack bulk bearings ($10 for 10) they are way better than the Losi bearings and way cheaper.
Rex
Rex
For any other clutches to work on the Lousi you need to shim out the flywheel 2.5 mm and use that Ofna clutch shim kit with the little black shaft extender that comes with it , but you need to pay close attention to the bolt you use to hold it on , if the head is not a buttonhead it's too long, you will ruin your fuel tank ! Also you may need to shorten the extender a touch so you use minimal shims.
I use a Kyosho clutch in my Lousi (which will soon turn into a RC8) and have no troubles what so ever !
I wanted to keep the stock engine location so I just shimmed the flywheel forward, but if yo uwant to mess with the weight distrabution go for it ...
Nope not a pro , but I have been at this since 1988 ,and can I tell the difference.. YES I can . But hey I'm not you so you can take all that is posted with a grain of salt and do as you may.
