HPI Pro 4 - Motor + ESC + more Help ..
Well im new and im prob goona get a HPI Pro 4 .
Can you please tell me if these prices are good ..
Mtroniks Plasma Sport Plus Brushless 4400KV Motor - £49.99
" 480 can size (with 540 adapter plate)
Weight = 145g
KV rating = 4400
Operating voltage is from 4 to 7 cells
Equivalent to a 10 turn "brushed" motor
HS625MG Hitec High Torque Metal Gear Servo - £32.99
Torque 4.8/6.0v = 5.5/6.8kg
Speed 4.8/6.0v = 0.16/0.13 second
Size = 40 x 20 x 38mm
Weight = 55g
Dual ball bearings
Mtroniks Viper Truck ESC - £49.99
100% waterproof
Forwards, brake & reverse with 15 turn single motor limit or 2x 27 turn motors
6.0V to 12.0V operating voltage
Built in failsafe to protect against signal loss
Short circuit and motor overload protection
Digital one touch setup
Adjustable features include brakes, reverse disable and reverse delay
Dimensions : L39.0mm x W34.0mm x H13.0mm
Weight : 55g
Capable of running up to 4500mAh cells
Car
£73.41
Part's
£49.99
£49.99
£32.99
£205.56
£205.56 - For HPI Pro 4 And all electrics anygood ??
Weight = 145g
KV rating = 4400
Weight = 55g
Dual ball bearings
100% waterproof
Weight : 55g
Car
£73.41
Part's
£49.99
£49.99
£32.99
£205.56
Hello mate
u have abit of a problem because the esc is a brushed esc and your motor is a brushless so unfortunately they will not work together.... is all this kit new or is it secound hand? if its secound hand then i would say no you're not getting a good deal, but if its brand new then you are paying still abit to much for the esc and motor, but seem to be getting a good deal on the car.
Steve
Steve
