ROAR Stock TC Guideline Suggestion
#76
If you want to make it really easy for a newbie to get into the sport of racing
Chasis price limit with silver can and only stick packs allowed.
This class will fix a lot of things
1) Initial cost to race.
2) Silver Can has less speed no motor sponsors
3) Stick packs will make it simpler to charge and discharge.
#77
#78
I hate to even introduce this thought into the thread but if everyone is serious about decreasing costs and slowing down ROAR has already proposed an aswer.
5 Cells.
I'm not even sure I like the idea myself. But its worth discussing. Since stock racing is so battery intensive racers could save almost as much money if their packs cost 17% less than they do now.
5 Cells.
#79
I've said it before in one of the few hundred previous threads on this topic, that you cannot FORCE someone to run in a particular class.
What you CAN do, is make the stock class less attractive so that they won't want to run it anymore. Another thought is to stop announcing the sponsors for stock class participants before the mains. Magazines can help by not listing their equipment in the results...just use their names.
You would get 20+ of the worlds best drivers running in a factory stock class (and out of stock) with a complete kit anyone can get off the shelf of their LHS. Factories would get their glitz/glam magazine moments and the race on Sunday sell on Monday principle of marketing is still met. Run a points system to see who the top manufacturers and drivers are.
Us mere mortals would be able to see what the cars are capable of without dropping a fortune on option parts or getting into motor and battery wars. Stock racers would get some room to move around in the stock class. Stock racers wouldn't be competing with custom machining and prototype parts that are only available to the factory drivers. And it would be some sweet racing.
Chris
#80
My club has an entry level class that is 4 cell,/stock motor/rubber tyres.
Having been through it myself, I think it is a great learning class for driving and set-up w/o having to worry about motors and batteries as much. Motors go a lot longer between cuts, there's no need to worry about adjusting the car as the foams wear down and most of the people running it are just buying last seasons batteries from the 6 cell racers. At that level, the batteries and chassis do not matter as much because the driver who wins is the driver who keeps the car off the wall.
It's also quite slow so you rarely get anybody who stays down in the class for more than a couple of seasons before stepping up to our 6 cell/stock/ rubber class and they are better driver's for it. It certainly cuts down on the guys who come out once, run 6 cell stock, break everything on their car and then you never hear from them again.
#81
Car chassis are much more expensive than they used to be. (I don’t remember paying $400 for my HPIRS4 Pro back in the day.) Between the increase in chassis cost, stronger motors, better batteries and the fact that tourers are not as crash resistant as they used to be, new people getting into this segment of the hobby better have deep pockets or be pretty skilled at keeping the cars off the barriers. Otherwise, they are spending a lot of money on spare parts or spending a lot of time in the pits rebuilding from their latest run in with the wall.
You want to grow stock touring again? Make it a little easier for the new guy to get started and to stay with it. When we were all running RS4 Pro’s (or insert your favorite chassis of the day here), we were many times running on less than perfect surfaces with barriers that were not too rough on the cars. (Corner dots and garden hoses come to mind.) We didn’t have 15 bazillion rubber tire/inserts to choose from, we were not running foams, we didn’t have a gazillion tools to tweak cars all day long for that extra 10th of a second gain in lap times. There generally were not guys with sponsorships everywhere you turned either thus making it a little easier for guys to stay competitive.
I have to think if this class ends up dying out the manufacturers are just as much to blame as the racers for giving out sponsorships to everyone and their brother instead of just a select few that drive in the fastest class (modified) at the biggest events.
#82
+1
#83
Keep in mind, that with a change in stock class....you just might have to change 19-turn as well. It would also have to slide-back some to remain a middle-ground between stock & mod. The jump from "new" stock to 19Turn would be too big. Maybe go with the 23-Turn system used overseas.
Also, on the subject of reducing the number of cells it would slow the class down but it is also harder on the batteries. This has been documented by both the Japanese (4 cell) and Europeans (5 cell). Both of these also rule out LiPo and that's a bad idea IMO.
#84
I agree McSmooth.
If you're worried about lipo and brushed, then stock should be 35 turn with full stacks, like a 19t arm, and maybe go to the 23t motor for 19t, since it is available anyway.
#85
5 Cells.
5 Cells.
One less cell means slower.
Slower means corner speed is more valuable.
More corner speed means stiffer chassis.
Stiffer chassis means more money.
So what you save on a battery pack goes right into the chassis.
Also, a car that costs $100 less is better than a battery pack that costs $10 less.
#86
Ok, say we decide to approach ROAR and request Stock TC class rules be changed to require 27T full stack, 17.5/19.5BL, , (insert your motor choice here), etc. How do we go about officially requesting that? (Hi Jim!)
Secondly, what is ROAR's internal process for making such a change? What hurdles are they going to encounter? Which of those hurdles can we lower to make the chance of success greater?
Lastly, since ROAR is a racing organization, do they have any precedent of making rules for the so called NOVICE class that may or may not be raced at their State, Regional, or National events? In other words, can ROAR write rules for a class they MAY never see run at their events? Not that the class couldn't, shouldn't, or wouldn't be run at the big races ..... it just seems unlikely at this juncture.
#88
I like the simplicity of your concept! It's broad enough to encompass everything, but still accomplishes the goal, and is inherently simple as well. Maybe there's another idea that can come from that mentality?????
#89
