GT class--buggy-based on road! >
Old 10-21-2008, 09:35 AM
  #1351
rpespo's Avatar
Trader Rating: 12 (100%+)
Originally Posted by vadn1
Good job on your race. Proof to show that Mod and Stock can run together, and racers can still have, "...a Blast," with stock capable of get a podium finish.....
Thanks, but there was also alot of luck involved in getting the podium too. During qualifying the mod cars were much faster than me and I figured I didn't stand a chance against them. All I wanted to do was try to run consistant and finish the race. Well during the main, one car ran out of gas, one did not start and two broke. Also, the track was very slick, the air temperature was only about 62 degrees and breezy. I think this helped to equalize the field a little too. If it had been warmer and the track had more grip I probably would have gotten blown away. Bottom line though was I had fun and didn't have to spend alot of money.
BTW... 3 days of racing in 2 classes at 301 for a total of $35 in track fees!!! Can't beat that!
rpespo is offline
Old 10-21-2008, 10:33 AM
  #1352
Trader Rating: 32 (100%+)
For those who have been waiting.......
Kyosho IGT2 Corvettes are shipping to dealers NOW!!!!
JDCrow is offline
Old 10-21-2008, 02:22 PM
  #1353
Originally Posted by Jspeed
Vad,
The Kyosho IGT2 in the picture is a Japan only car in kit form with the Sirio. Its not RTR or being marketed in the USA. If you want to learn more about it go to www.kyosho.com.jp
You'll have to dig deep to find it, its well hidden and you'll need to be able to read japanese to find it.
Racing the GT cars is not as expensive as 200mm or 1/8 scale but everyone pays the same for race weekends away on the road.
Jeff,
Thanks, I was looking under the Kyosho Japan site but the english version, couldn't find it so I stopped searching. Yes, you are right, we all have to pay the same for race entry fees.
vadn1 is offline
Old 10-21-2008, 03:08 PM
  #1354
kmichael's Avatar
Jspeed,what's up dude good to hear from you we hadn't talked in a long time, guess we both been busy well no I'm not the big time racer just a hobby guy you know old school I like building it and see if it fly you know trial & error that's make it a hobby and fun for me just weekend fun rtr is not a hobby but it's good for some,if that's what works for them more power and have fun but like I said leave some fun for the guys that like to build peace bro and don't be a stranger
kmichael is offline
  #1355
kmichael's Avatar
sorry hit it twice
kmichael is offline
Old 10-21-2008, 03:22 PM
  #1356
DJ,
Can you tell me your setup on the DM-1, 2 speed. I am out 6 1/2 turns on both bolts. If I go any further out with the socket head bolts start rubbing on the inner rim of 2nd speed holder. I need my car to shift sooner. I am running the DM-1 with a novarossi .21 RX21RR1N (dont know if that helps). Any suggestions?
vadn1 is offline
Old 10-21-2008, 03:37 PM
  #1357
-R2-'s Avatar
on my two speed it is 4 turns in from the top of the shoe on each side.And you would start from the lowest part of the hole where the set screw goes in.
-R2- is offline
Old 10-21-2008, 07:47 PM
  #1358
Trader Rating: 11 (92%+)
Default help!!
I just finished purchasing a kyosho inferno gt2. but i am having problems with my engine. i have yet to do the break in. the engine wont idle for more than 2 second. i raised the idle screw but than it was too high and engine got hot.the main needle was set to 3 turns open. not sure the low.
any tips would be greatly appreciated.
Elies12 is offline
Old 10-22-2008, 06:04 AM
  #1359
bigemike's Avatar
Trader Rating: 36 (100%+)
try using a heat gun to get the engine to about 180
make sure there are no leaks in the fuel system. and the fuel cap is shut all the way. Also leave your glow ignitor on the motor until you get it idling good
bigemike is offline
Old 10-22-2008, 07:22 AM
  #1360
Thanks for tip, u think they can be an air leak even though its brand new?
Do you have a good starting setting with the carb needles? cause i turned all of them and dont know the original settings
Elies12 is offline
Old 10-22-2008, 07:43 AM
  #1361
Default Carb settings on GT2
It appears, unlike the initial Infernos that were shipped, the carb settings shipping on the GT2s are random.
When I tried to start it up the first time, the RPMs were way up there (hopefully I didn't mess up the engine because of such). I haven't had time to figure it out and break it in since.
The instructions do state 3 turns (I believe) on the high-end mixture but I couldn't find anything in the instructions for low-end or idle.
Anyone have any suggestions for initial settings?
barrys is offline
Old 10-22-2008, 07:45 AM
  #1362
Yes my engine had the same problem idles way to high..was getting hot
Elies12 is offline
Old 10-22-2008, 09:50 AM
  #1363
impalabob64's Avatar
Default Try this
Set bottom to rich settings ,set hsn flush you may need raise idle because the bottom will be rich,get it running then start leaning the bottom alittle at time until you get a steady idle.My last gt i broke in by driving it at half throttle for about 4 1/2 tanks basicly like the you do the revo or t-maxx breakin this seems to work best for me.hope this helps.
impalabob64 is offline
Old 10-22-2008, 09:59 AM
  #1364
Where should i start the low needle? how many turns?
Elies12 is offline
Old 10-22-2008, 10:09 AM
  #1365
Default Setting
Set it flush then lean it,you will hve to try an keep it running, give it short throttle bursts,start working with the bottom end first.
