GT class--buggy-based on road!
#6466
RB Killer 10 .21
Does anybody have the specs (RPM & HP) on an RB K10. 21? If you own one I'd like to hear your pros & cons. Thankyou!
#6467
A new Warrior cometh!
#6468
#6469
William is right, the arm is meant to flex if pushed on (ie. you come off a big double and land on one arm, the arm will flex instead of snapping). In on-road racing conditions there is really no force that pushes the arm past the setting point, so you should be good to go with your setting.
#6470
Thanks guys very much for responding. The arm is flexing as you suspected. With us running 200mm touring and 8th scale I wasn't looking for arm flex. That's the story I am sticking with anyway. Now that I have that out of the way, I can get back to over-analyzing the car!!
#6471
#6473
The Texas Biggie was a Blast!!! Congrates to all the winners. I decided to attend this race 1 week prior, and for less then $300 bucks spent with IGT hobbies and help from all the Austin,Tx GT crew converted and old HotBodies D8 buggy into a GT racer.
I did fairly well at the race considering all, and enjoyed the whole weekend. Car will get better by next race. Did put down second fastest lap of the A-main.
But overall you don't have to spend a ton of $$$ to get into GT racing, its a simple and a ton of Fun to run. Just use the K.I.S.S. rules to make the class grow and encourage new racers. As in any form if racing Speed=$$$$$$$, but it doesn't have to be.
See you guys in SATX SWCS race#4!!!!! I will be ready!!! LOL
#6474
dnf don,when you hittin up leisure? ran 2 tanks thru mine waiting on a body and some tires.
#6476
#6477
Does someone know the correct part number for the stock GT1 chassis? I ordered one online and I got ittoday, but it doesn't have the two speed cut out and mounting holes(buggy chassis). So I dremeled it out and drilled some holes to mount it up but now it seems like the kick up isn't the right angle and by front bulkhead will not line up with the top plate? If I try to force it the front drive binds. I have all the correct parts for the conversion from GT2 to 1 but I need the chassis.
gt1 chassis IF146B
#6479
Need to cut my body out today and have a gt expert at track set my 2 speed trans up and im rdy to run this missle
wehooo onroad time baby
dnf
dnf
#6480
