GT class--buggy-based on road!
#5731
Got some binding in my front brakes while in neutral! I have about 2mm of play from where the screw secures the brake pads. I have about 4mm of play from the brake linkage ( fuel tubing to brake lever). It looks like the brake disc tilts then get caught on the pads. Has anyone had this problem before? You think the brake disc needs just to be broken in? What are you thoughts on this? It's a DM-1 spec w/ center diff and added front brakes.
#5732
not sure on that car, but they little springs that actually go over those screws to push the plates open. You should have a minimal amount of play on there as possible before they touch, or tighten till it just touches, than back of a 1/4 turn or so more. hope this help's. The springs mentioned i used on 1/8 buggy's, i know O'Donnell makes them, and many others, call your lhs and tell him what your looking for, the springs are a must have, i put them in my igt2 as a standard part.
#5733
http://www.amainhobbies.com/product_...ator-Springs-8
#5736
Thanks! And these parts fit right in, no hassle or mods? Bassman2, what spacers are you talking about exactly? Do you have to shim the outside of the CB or something?
I think I would prefer to stick with stock gearing - 16/20... Can even imagine going up to 17/21.. The straight at the local track is REALLY long....
EDIT - ps, damn, the Kyosho parts are a lot cheaper too....
Put the pinion gears on the clutch bell (not to tighten them completely) then hold the clutch bell assembly against the complete assembled Ofna tranny then you'll see clearly how much gap you'll need between the 1st and 2nd pinion gear based on the spacing between 1st and 2nd spur gear. Then use an old bearing outer shell or some shims (that will fit over the threads on the clutch bell) to create the necessary gap that you need in order to have good mesh between all gears. I hope this makes sense to you.
#5737
http://www.amainhobbies.com/product_...Bells-Shim-Kit
#5738
this OFNA kit is great for shimming your flywheel and clutch as needed to fit correctly.
Brian,
This shim kit will not work for creating "gap" between 1st and 2nd pinion gears. He'll need shims that will have big enough inner diameter to fit over the threads on the clutch bell.
Good luck at the Vegas race buddy
#5739
Anyone know what the kick up on the GT2 chassis is? I sent a few bent chassis home with a guy at work to straighten them but he removed the kick up also. So now I need to find out how many deg. it should be at so he can put it back in the chassis's.
#5743
Thats cool guys, I knew the Kyosho clutch bell worked on Serpent's GT prototype, but hever knew it could be used in the Ofna too. This should help a lot of DM1S racers around the world. Very cool indeed!
#5744
#5745
The blue chassis on these cars are very soft. I would consider the SP chassis kit from Kyosho, KYOR246-3501, if you have the GT2. They are made from 7075 alloy. They made a similar chassis for the GT1 cars, but I'm not sure if they are still available.
