GT class--buggy-based on road!
#436
Jeff,
Most of us are running 50K to 100K in the front diffs, 10K to 30K in the rear, 45w to 80w in the shocks, front toe out + 1 to +2, rear toe in -2 to the 3 degree stock rear block, camber -1/2 degree to -2 up front & -2 to -4 degrees rear, sway bars front & rear. Set your ride height as low as you dare!
#437
Jeff,
later
Jeff E!
see ya in kissimmee
#438
This is kind of bouncy... but I was doing some hotlaps with a camera on board. The weather timing (it's snowing now) didn't allow us to setup a track so I ran the tri-oval perimeter... Can't wait for Spring...
http://youtube.com/watch?v=AMXcxiYTutY
#440
Done.
.... and I still have your blue springs.... I'll get them back to you at that race.
#442
diff oil 100,000 front 30,000 rear
shock oil 700 F 900R
ride height 7F 9R
Camber 1.5F 3R
Droop 1F 4R
If you are going to the state race next weekend I can bring my hudy setup system & get you going
#444
Is there a track in So Cal that has a class for the GT's?
#445
Finally got a chance to run my IGT at Bvoltz' Bass Pro Series race in Jackson, MS this past Saturday. Thanks Jspeed for the setup tips that you used. I modified a couple of points slightly but overall, it worked like a charm. I set TQ for the day and was 1:45 seconds short of winning the main when my car just stopped. That dropped me all the way down to fourth place. Found out after I got back home to Dallas, TX, that the conrod in my engine snapped and broke the sleeve and poked a small hole in the crankcase. So, I am going to make a plea to the guys that have modified their cars: If you have the stock motor that you are willing to part with, PM me with details and cost of how much you are asking for it. I will need a new engine for the next race April 12th, especially since their is no modified class in the Jackson, MS series. Outside of the engine detonating, I had a blast with the car. It was much more fun than running my 200mm touring car.
#446
Finally got a chance to run my IGT at Bvoltz' Bass Pro Series race in Jackson, MS this past Saturday. Thanks Jspeed for the setup tips that you used. I modified a couple of points slightly but overall, it worked like a charm. I set TQ for the day and was 45 seconds short of winning the main when my car just stopped. That dropped me all the way down to fourth place. Found out after I got back home to Dallas, TX, that the conrod in my engine snapped and broke the sleeve and poked a small hole in the crankcase. So, I am going to make a plea to the guys that have modified their cars: If you have the stock motor that you are willing to part with, PM me with details and cost of how much you are asking for it. I will need a new engine for the next race April 12th, especially since their is no modified class in the Jackson, MS series. Outside of the engine detonating, I had a blast with the car. It was much more fun than running my 200mm touring car.
#447
Thanks for the heads up. I was using 30% when my engine detonated. I have been so use to high-quality engines like Novarossi, OS, etc, I forgot that not engine can handle the higher nitro content. I guess when I get another Kyosho powerplant, I will have to 20% in it as not to blow up another one.
#448
Glad to read you had fun racing the IGT Spec car with Barry. at Bass Pro.
Believe it or not, I’ve found that the factory engine runs very happy with Werks Racing 16% fuel. It makes plenty of power and runs much cooler with it. The engine protection available from Werks Racing fuel is incredible!
If you haven’t tried it yet, you should.
#450
Honestly, I don't know about their availability. Through my main LHS in Carrollton, TX (Mikes Hobby Shop), they have difficulties getting things from Kyosho USA. However, Zootcapri may have an engine that he is willing to part with (I believe that he may have modified his to the SS class). I have at least 3 weeks before it becomes crucial, so, I will be tracking one down.
