NovaMega SX12 Problems!
I've got a Serpent 705 with a brand new NovaMega SX12 engine and a Serpent PowerStart starter box. The engine has never been started up or anything before, well when I put the car onto the start box, the rubber wheel starts smoking and the flywheel hasn't even been turned once. I have the button adjusted properly and I am pushing down hard on the chassis, yet it won't start. It's like the engine has too much compression making it impossible for the flywheel to be turned, I can turn the flywheel by hand when I have the engine in my hand, but it is pretty hard to turn.
Any advice is appreciated.
Originally posted by tony montana
try and slightly loosen your glow plug, just about a less than a 1/4 turn until it fires up then tighen it back up, should be fine after a couple tanks. I kind of have a dumb question since you have a 705 were does the switch mount on the chassis?
As far as the switch goes, there is no particular place to mount it. I driled out the top plate and mounted it in between the gas tank and the throttle servo.
