Hpi Pro 4
Originally Posted by rush evo dude
wow! looks nice!
i would like something like that.
so is it 2 or 4wd?
i have a kyosho chassis that's 4wd.
what's better, 2 or 4?
Rush evo dude
P.S. sorry for the questions
so is it 2 or 4wd?
Rush evo dude
Originally Posted by GreaseMonkey
Well, I'm just getting into racing (I've bashed for about a year) and the starting class at my local track is 4 cell stock with rubber. I figure i'll start there and work my way up. At the moment it's the quiet season so a good time to learn. I probably won't race till the fall, just practice for now.
Originally Posted by rays_tt
hey guys just got my pro4 and just wna race it in 540 for the time being to get some practice under the belt, whats the perfect ratio for 540 on the pro4?
Thanks.
Thanks.
If you are using the HPI 64 pitch spur gears which i suggest you dont (they strip and get damaged easily, and the HPI parts pretty much wont give you top speed) then you need to go the smallest spur i think its a 94 and largest pinions.... i think 48-50
Note that i run a heatsink/fan on my motor and also clear out as much room around the motor as possible to try and get good airflow/cooling.
Oh BTW my starting preference is around 39 pinion/69 spur
Thanks.
Thanks.
Is there's an option to enter your motor type on gearchart now???
I think you need to know its rpm.
What's the biggest 64 pitch spur gear I can get into the Pro4?
I just found out the hard way that not every gear will fit. I bought a 111 tooth 64 pitch spur and a couple pinion gears to get my final drive between 6 and 7.5 and the spur gear is contacting the chassis.
Am I missing something here?
Had my first evening out with the car tonight. Just gettign used to it and learning (Thanks MATTS if you read this) and as it would, a front lower control arm got broken (funnily enough not by me). I was told to get a softer compound arm as it stands up to accidents better but the steering can be less responsive. Does HPI make the arms in softer compounds or am I stuck buying the stock ones (73506)?
Now my question...I am tearing up cvd's left and right. My car is totally uncontrollable (running a spool in the rear, one way in front) with the 4.5 on asphalt. The springs are neo yellow (stiff) and whenever I go into a turn, it's like drift city. Which tires are the best to go with this high speed set-up? I am running the Hara Pro 4 and while it is a rocket, this uncontrollable-ness in turns is really a downer.
Originally Posted by bxpitbull
Well, if you are looking for balls out speed and you are running the GTB/4.5 combo, go 64 pitch 98/24. This will give a 9.9 final drive and the car is a friggin rocket. Motor stays cool (140 ish) and depending on your cells, I am getting 10 minutes on IB 3800's.
Hmmm mustve been a pretty big hit to break a front arm in 4 cell stock
Are these the ones you are talking about????
http://www.rcmart.com/catalog/produc...ducts_id=11528
Ive got some but have never tried them, they are NOT meant to be good for carpet as they are designed to give higher traction
Actually i take that back they are good for carpet
HPI's High Traction Suspension is made from softer material plastic compound than the standard graphite-plastic suspension arms, these arms are ideal for use on high-traction track surfaces such as high grip smooth tarmac and carpet.
