Like Tree86Likes
Hpi Pro 4
Old 08-17-2005, 08:00 PM
  #12541
floodo1's Avatar
here im lazy so only this pic:
idk about you but those look like steel screws to me! even on the top!
check out any pics you can find of factory hpi/hot bodies guys, more than likely they are running steel.
anyway no matter, the theory is still sound, all weight you would add will be above the top surface of the chassis, while the screw head resides below
floodo1 is offline
Old 08-17-2005, 08:26 PM
  #12542
ChadCapece's Avatar
On an aluminium bulkhead car, there aren't many metal to plastic screw housings. Most are screws into aluminium. Notice the top decks and the bulkheads.
Also, when a car is 100 grams underweight, why not run steel screws to keep from snapping an aluminium screw during a race? I bet Aluminium screws save a max of 5-10 grams over SS or Ti. screws.
ChadCapece is offline
Old 08-18-2005, 02:30 PM
  #12543
rc-zombies's Avatar
Carpet season is just around the corner..
and want to try it out...
so who's got a good carpet set-up?...other than the ones posted on the
HPI website....
rc-zombies is offline
Old 08-18-2005, 02:42 PM
  #12544
fjm9898's Avatar
Trader Rating: 11 (100%+)
what ya running? foam/rubber
fjm9898 is offline
Old 08-18-2005, 02:47 PM
  #12545
rc-zombies's Avatar
19T / foam
Old 08-18-2005, 02:56 PM
  #12546
fjm9898's Avatar
well for staters either get the bmi 3mm chassis and top deck or the buy the 3mm chassis from HPI. well, i dont run foam so i cant help you very much past that. but for sure you need a 3mm chassis
fjm9898 is offline
Old 08-18-2005, 02:59 PM
  #12547
rc-zombies's Avatar
yup..already have those 2 chassis inmind....
Old 08-18-2005, 03:30 PM
  #12548
ngo8's Avatar
do you guys have the part # for the new updated motor mount that comes with the hara edition pro 4 also the shocks and the one piece bevel gear its almost onroad season not yet but coming soon i just want to upgrade my pro4 to hara spec thanks.
ngo8 is offline
Old 08-18-2005, 03:31 PM
  #12549
rc-zombies's Avatar
HPI website has the full parts list for the Hara Edition.
Old 08-18-2005, 03:53 PM
  #12550
ngo8's Avatar
ngo8 is offline
Old 08-19-2005, 01:19 AM
  #12551
Skill's Avatar
I'm using the PRP chassis kit on carpet with foams and I love it!
The springs I'm running are quite stiff, I'm using the old range of HPI linear 25mm springs, green on the front and red on the back. I'm also running a black rear sway bar, and both front and rear shocks are fully stood up on the towers. I'm running 32 shore HPI foams all round without additive.
Everything else is pretty much stock setup, but hope this helps
Skill is offline
Old 08-19-2005, 07:55 AM
  #12552
floodo1's Avatar
pretty much my point. but you can run al/al, just use anti-sieze....actually you dont even have to do that! in oval we run al/al ALL the time! i think because both parts are annodized and the screws get removed every once in awhile you end up with no problem.
floodo1 is offline
Old 08-19-2005, 05:07 PM
  #12553
the_barbarian's Avatar
OMG is it here
http://www2.towerhobbies.com/cgi-bin...?&I=LXLBD7&P=0
the_barbarian is offline
Old 08-19-2005, 05:10 PM
  #12554
fjm9898's Avatar
just FYI its been on towers page for 2 weeks. also for anyone wanting to know what parts from the Pro4 will fit the Cyclone. check out the cyclones thread, Steve from speed tech got a parts list in and will be giving a list as to waht parts are the same
fjm9898 is offline
Old 08-20-2005, 09:17 AM
  #12555
ngo8's Avatar
just wondering is anyone planning on running a cyclone on carpet the car looks good but hoe good will it be indoors and wilo there be a diff available ?
ngo8 is offline
