Hpi Pro 4
You guys run front DIFF or front 1-way on outdoor parking lot track..? I will say the turns are medium size.................
I used to run 1-way (no stripping problem)....then changed to front diff....then I am always UNDER.....and gear stripping problem.
I might go back to front 1-way just to make sure I don't have those annoying gear stripping noise...
Originally Posted by fjm9898
where can i get the 2.25mm top plate for cheap and fast
RainbowTen in Japan...usually get my order in 4-5 days.
Originally Posted by rc-zombies
this part:
my shimming is close to the stock set-up.
you don't want it tight...there should be a little play.
Thanks for the shim tips....I think I will have to replace the lower diff case so the small shims will not have the extra play.
how do you use rainbow 10? how do i find the 2.25mm top plate
RainbowTen is kinda tricky....to order from them, read the section on "how to order" and to find parts you've got to use the search tools. Choose "R/C CAR and Parts" in Genre, Leave "ALL" for manufacturer, Leave the Scale blank and type "HPI" in the keyword. That should do it.
This is what I got:
*73109 PRO4 UPPER DECK 2.25mm(WOVEN GRAPHITE), 1
This is what I got:
huh i dont see it on the list goes from 73085 to 73410
Yeah, I noticed that just now. That may mean they're out of stock. I still sent the order in anyways and I got it eventually. Didn't take very long. You could always try rc-mart.net too.
rcmodel in Hk has it instock...and they take paypal...
Rookie what camera did you use for those pictures? Those are excellent quality.
I just ordered quite a bit of stuff from www.precisionrc.com They seem to have just about everything for the Pro 4. Including square and jet parts.
they are from the HPI website.
Originally Posted by Rookie Solara
Hi Everyone,
I have a few question on the pro4.
carpet season is coming up in east coast, just wondering if I pick up a BMI chassis, will it be stiff enough for the carpet seasons?
Thanks,
Ming
Thanks,
Ming
Originally Posted by yellow15
What motor is that?
I have seen posted on here a few times, some of you guys referring to 1.1 version diff gears, what is the difference between these 1.1v and the ones that come with the Hara edition?
The motor shown in the pic are the new HPI 23T R2 Stock motor - they come in 4 different type SS, TS, SL, TL. The 1st letter S = Speed and T = Torque. The 2nd letter is the brush type - S = standup and L for laydown. They are simillar to the Orion Katana 23T.
