Like Tree86Likes
Hpi Pro 4
Old 04-25-2005, 12:52 PM
  #10996
Trader Rating: 17 (100%+)
Originally posted by brushless
I mean next next Friday. May 6th. I'll try rcmodel and see what the shipping comes out to.
The recent purchase from them.......a set of 3PK....4 days, with their typical EMS shipping...from HK to Chicago.
1 time, just buy a NTC3 carbon side brace from them....$20 US item, shippping is $3...........from HK to USA...took 5 days.
$3 international shipping within 5 days 5000 miles away(I think..).........you cannot even ship one pinion gear from Chicago to Indiana for $3 US
Solara is offline
Old 04-25-2005, 12:57 PM
  #10997
brushless's Avatar
On my web site, I've given my customers the option to choose USPS First Class shipping which starts at around $2.73 for them. When they order 1 or 2 parts, they choose that shipping method most of the time too.
brushless is offline
Old 04-25-2005, 12:59 PM
  #10998
Originally posted by Guo Chean
do we need to true the foam tire inorder to run smooth? how many tire diameter need to true? thanks
Yes...2 words, TRACTION ROLL
I am no expert, but have been told to use Parma foam, trued down to 59mm front and rear, or 60 rear 59 front.......then it will last you good 2 sunday racing...........
make sure CA the edge of the foams too.......
About the setting........way too many, someone here can help....I forgot my indoor setting, I am doing outdoor mod foam setting now.
Solara is offline
Old 04-25-2005, 01:39 PM
  #10999
Exe
Exe's Avatar
i have just ordered stuff from HK, seems like prices on ems shipping in hongkong has gone up
for 6 kg's i paid 210$ for shipping ;///////
Exe is offline
Old 04-25-2005, 01:43 PM
  #11000
Originally posted by rc-zombies
1. 3deg
2. 1deg hubs.
why do you need so much rear toe-in?
I am running a very short and tight track.
Snikkari is offline
Old 04-25-2005, 02:16 PM
  #11001
Exe
Exe's Avatar
rear toe in give you more rear traction under acceleration, but going more that 3 degrees i think it will make worse.
Exe is offline
Old 04-25-2005, 03:16 PM
  #11002
Brushless...Motor heatsink,On most of the new motors the heatsink wraps around the can and blocks the air flow from the armature increasing heat.
Pro 4 parts....USA www.speedtechrc.com
HK www.precisionrc.com
Both these sites have exellent service and heaps of parts including aftermarket parts...Tobe square etc
Barger is offline
Old 04-25-2005, 03:28 PM
  #11003
From all the brushless ppl that I know....none of them need to add heat sink onto their BL motor..........but they all have fan(s) to blow toward their ESC......plus vented hole on their body....
Seems like the thermo shut off are what they concern more then the motor itself, they said their motor rarely get extremely hot if you geared correctly.
Solara is offline
Old 04-25-2005, 03:31 PM
  #11004
Exe
Exe's Avatar
yup.. esc overheating is the main concern. i drive with a fan on uforce on novak also, but even esc does not help for novak to hold 5 minutes when racing shut off 2 meters before finish line on last lap
Exe is offline
Old 04-25-2005, 11:06 PM
  #11005
Trinity2's Avatar
I was wonder. Are those guys how drive HB Cyclone... like Hara he use stock springs?
Trinity2 is offline
Old 04-26-2005, 08:41 AM
  #11006
Skill's Avatar
I think Barger is right here that motor heatsinks only work if they are not blocking the vents for the motor, if they block the vents then they stop all the warm air getting out and the cool air getting in.
Skill is offline
Old 04-26-2005, 08:51 AM
  #11007
rc-zombies's Avatar
the Eagle/Integy heatsink is vented to allow air to pass through.
rc-zombies is offline
Old 04-26-2005, 09:33 AM
  #11008
I used this on my 8T V2 motor running outdoor with track condition can be over 90 degrees sometimes. yes, it does look like a geek, like a rookie..........but it does work.
http://www2.towerhobbies.com/cgi-bin...?&I=LXHAZ7&P=0
Solara is offline
Old 04-26-2005, 10:31 AM
  #11009
rc-zombies's Avatar
I filed a channel under the chassis to improve airflow to the motor.
Old 04-26-2005, 07:10 PM
  #11010
loopedeloop's Avatar
Default Question
Is there any reason why I couldnt use my .5 degree rear hubs on the wrong sides to reduce rear tow in.
just seems easier and cheaper than buying new pivot blocks.
geoff
loopedeloop is offline
