Like Tree86Likes
Hpi Pro 4
Old 04-07-2005, 08:27 PM
  #10786
Guo Chean's Avatar
second pic
Guo Chean is offline
  #10787
Guo Chean's Avatar
third pic
Old 04-07-2005, 10:58 PM
  #10788
rc-zombies's Avatar
where's that new body for your car?
rc-zombies is offline
Old 04-07-2005, 11:40 PM
  #10789
Guo...Your car looks great.....almost the same as mine!!!!!!!!!!
I cant see in your photos but have you done the top deck mod?(Drill out the top deck were the screws go thru to hold the front/rear bulkheads) I found that was the biggest inprovement to stop tweak.
Also do NOT make the same mistake as I did...Used a carbon shaft for Mod...It twisted the shaft 180 degrees!!!!
Barger is offline
Old 04-07-2005, 11:49 PM
  #10790
axel's Avatar
Wow that;s a nice pro4. Almost like ramon's. He's got one hopped up pro4. good thing he sold me his BMI pro4
axel is offline
Old 04-08-2005, 12:55 AM
  #10791
octavio's Avatar
Default Spur and Pinion in 48 Dp
I would like to knw which SPUR and PINIONS in 48Dp will fit on the Pro4. And pinions will have to be short, so no motoplate will be needed.
Please give me some brand names ? thx !
I also made an excel-sheet with gearratio's in 64 and 48 dp for the Pro4 :
Pro4 gear ratio
octavio is offline
Old 04-08-2005, 01:59 AM
  #10792
Trader Rating: 17 (100%+)
Use kawada pinion would be fine
EngTat is offline
Old 04-08-2005, 02:04 AM
  #10793
oops i am not sure about the kawada 48p pinion
EngTat is offline
Old 04-08-2005, 02:08 AM
  #10794
jihernandez's Avatar
Originally posted by Guo Chean
third pic
Am very interested to see the mod coz it would be hell trying to find the page where this is discussed.
Can you post a clearer pic?
The pics are not clear in the portion where the mod was done. I think it is bec of the flash.
jihernandez is offline
Old 04-08-2005, 02:13 AM
  #10795
Guo chean nice car...i also wan to do the upper deck mod
EngTat is offline
Old 04-08-2005, 07:42 AM
  #10796
Trader Rating: 16 (94%+)
my car is running sweet at the moment, drivetrain is super free and handling is dialed, however I am having a problem whenever turning right on or off power i get a binding noise, similar to that of a stripped bevel gear....
ive pulled the car apart a dozen times now trying to find the source but everything looks perfect, the noise is only when turning right, left is no problem, any ideas?
domo is offline
Old 04-08-2005, 08:07 AM
  #10797
Mal
Registered User
Check your CVDs? There have been a few people at our track that have overtightened the set screw in the CVDs causing the pin to bend. This causes the CVD to bind at certain points ....
Mal is offline
Old 04-08-2005, 08:31 AM
  #10798
axel's Avatar
I've had this problem everytime i race. One was caused do to bevel stripping. I never realized it could be the cvd binding.
axel is offline
Old 04-08-2005, 08:36 AM
  #10799
Guo Chean's Avatar
sure have i drill from two 6mm hole rear 2 6mm hole i also modified the cone washer with o-ring in upper deck.
Old 04-08-2005, 08:41 AM
  #10800
Default 6mm holes
do you drill using normal electric drill or with a dremel?
I dont own a dremel. Is it possible to drill with normal drill?
BlueT is offline
