Hpi Pro 4
#8821
hi everybody! i just bought a pro 4 and i have a couple of questions.
--- i can't seem to adjust the diff so that it performs properly. i fully tightened the screw and then went back 1 turn loose but the diff is still not smooth. i ran a couple of batteries, thinking that it'll probably set in, but that didn't solve the problem. it feels like the diff rings touch the gear, as if the gear was thicker than the diff balls. i know this is not the case, cause the gear is free even when the diff is fully tightened. maybe the spring is too hard. so, if 1 turn loose is not enough should i go to 1.5 or 2 turns? this doesn't sound normal! how do you adjust your diffs? i used to unscrew my tc3 diffs 1 turn back from fully locked and they ran very smoothly, loose but not slipping. how can i achieve the same with the pro4?
-- the pro4 aluminum shocks are beautifull, but i have a problem with the shock cups. why do they have a small hole? is it for bleeding the shock? two of them i can screw on the shock body until they compress the bladder and lock the plastic ball cup you mount on the shock tower. the other two though, i can't tighten enough to lock the ball cup. first, i thought that the bladders were not thick enough and that the shock cup would screw all the way on the body, without touching the bladder. wrong, after disassemply i noticed that the bladders are similar but two of the cups had fewer grooves on the inside than the other two. the grooves hardly reach the (bleeding?) hole on the cup. are they defective? which ones are deffective, the fewer or the more grooves?
i hope the above make sense. any help would be appreciated!
#8822
The Pro4 diff is different from any other diffs I tried. Tamiya diff progresses the pressure as you tighten it where as hpi has constant pressure at the plates. Tightening the diff screw, make sure the outdrives won't slip and I do it just as close to slipping. Mine worked out pretty well after building it...was perfect.
#8823
There have been a few people having shock caps without the threads cut properly, just give HPI a ring and they should sort it out for you.
The small holes are for bleeding, thats what makes the HPI shocks so good, you just fill them up right to the top and screw on the cap, then the excess oil comes out and you get a perfectly built shock.
#8824
shock caps
#8825
#8826
I ran my two dodgy shock caps for ages before I bought some replacements, All you need to do is run a length of solder around the bottom of the cap, this way works really well, allows you to tighten the Cap up so it will not leak, only prob is that the front (in my case) shocks were slightly longer than the rears. I do not think that it really made a difference swapping to new caps, just gave me an excuse to rebuild the shocks. Jonathan
#8827
does anyone know where i can find a complete list of all the pro 4 option parts.
#8828
www.speedtechrc.com
Steve's got a great site, great shop, and great deals. Check there and look under http://64.70.208.72/speedtechrc/104.html
#8829
#8830
I had the same problem with the shock caps. I have one bad one. My boss/ LHS owner called HPI customer service and told them about it for me. They said they'd send one right out. After a few weeks I recieved nothing. So I just bought a gray one we had in stock so I could at least drive my new car. I then called customer service again. I told them my story, and also told them I had the version 1 gears. They were very apologetic and said they would send my shock cap and 1.1 gears right out. This was several months ago. STILL NOTHING. The car is excellent, really. The customer service is lame, however. Others have had good luck with HPI's customer service. But, I believe it was just that.... luck.
So currently I have a beautiful car with that one gray shock cap staring at me, and the old 1.0 gears. I'm running diffs since I'm inside on carpet for the winter, so I'm not too worried about the gears for now. When I get back to running a one-way or spool it may be an issue. It's just the principal of it all. I must admit that they were very courteous on the phone, but without results, coutesy only gets you so far.
#8832
hey guys,
I am running a stock pro4 on a really tight carpet track, with lots of "u" truns. I try the offical hpi "Thad"'s setup and it is pretty good. however I want to accelerate sooner when I get out of those U turns.
right now, the car seems to settle for a bit before it will accelerate again.
I see that my fellow racers can somewhat "glide" thru the U turns with lots of speed. ( is there any secret to that?)
I can't really copy their setup because they are using xray ft and tc4
any suggestion on the setup?
thanks guys
thanks guys
#8833
Yeucool...
what kind of speed control and radio do you have? How much rear toe are you running? Hows your gearing?
#8835
Pro 4 question
Do you have to remove the top gear case to remove the swaybar?
