Hpi Pro 4
#6631
Just wanted to add....
Guys;
That I am now running a Front diff (very tight) and did not have not one single part breakage all weekend.
I also now have the updated bevel gears (v.1.1), but have yet the need to install them in the car.
#6632
how come the diff keep comming loose..or this is normal?
I did tighten almost every run.
#6633
I just called HPI and they said that part number 73501 are the old bevel gears for right now. Hobby shops should be in the process of sending those parts back to HPI for replacement of the new parts. I still haven't needed the new bevel gears yet though.
#6634
#6635
As far as I was aware, the same part number is being used for the version 1 and version 1.1 gears. The 1.1 gears look slightly different, with a lot more material behind the gears, and the small gear has some extra plastic at the back of the gear.
#6636
The HPI guy didn't know whether the new parts would be under a different part number once they started shipping.
#6637
Originally posted by brushless
You need to read back a few pages. There is a fix for that. It's on page 217.
#6638
do they still sell the old gears anywhere, what am i gonna do with my prp brace =(
#6639
I have the PRP brace as well...the way it's working.... I may not have to replace the gears for a very long time...
#6641
Possible diff adjustment
FYI: I found that treating the Pro4 diff like a tc3 diff, compressing the spring several times before building and actually tightening it down fully they backing the screw out 1/2 turn has had excellent results in both my 4's. When the diff is new it needs to be run in a pack or two, to seat everything, then readjusted the 1/2 turn out method. I havent had to touch mine after I adjusted them this way. This may be helpful to some people who would rather try a set number of turns out, before giving up and switching out the diff screw, nuts ect.
#6642
PRO 4 Diffs
Just ordered my new gears this afternoon. Thanks HPI! Thats the HPI we are use to. Anyways my diffs quit lossening up finally. They must have broke in. Took nearly 3 months of racing every weekend. They have been fine for the last 2 months now.
#6643
Re: PRO4 RACING SHOCK SPRING
Thanks for this list RC-Z
I just got the blue white and yellows from Tower, they dont have the red ones in stock till later this month, and no mention of the pink one??
Originally posted by rc-zombies
Updated list:
Spring Rate gF/mm (lb/in)
273 (15.3) #6542 Blue
302 (16.9) #6543 Silver
320 (18.0) #6548 Pink
340 (19.0) #6544 Gold
363 (20.3) #6545 White
388 (21.7) #6546 Yellow
400 (22.4) #6547 Red
Updated list:
#6644
Re: Re: PRO4 RACING SHOCK SPRING
I have the red and pink coming from R10...
#6645
has anyone have tried both PRP and BMI chassis?
i'm looking into getting a set for carpet but not sure whether or not HPI to has their set released yet. which would be better?
any input would be helpful.
Thanks in advance!
Thanks in advance!
