Hpi Pro 4
#6271
Need help
What motor and servo do you recommend for HPI pro 4 setup?
Also, Is pro 4 cinsidered a sedan package or a oval package??
thanks,
thanks,
#6272
Re: Need help
depends what you want to race it in. I only have a futaba s3003 in mine...
thanks,
thanks,
#6273
Originally posted by azenis
Hi Thad
So you use a 2mm chassis.Yes,on asphalt tracks. how does that creat the extra traction?A chassis that flexes a little bit is more forgiving. If you have flex in the chassis it’s going to keep the tire in better contact with the track.You might loose some corner speed or steering but with some testing and setup changes you can overcome this. Carpet racing requires a totally different setup More flex? I would have thought flex to be a bad thing? I think the 3mm would be less prone to tweak as well?Tweak is caused by many different things, the chassis flexing and not returning to neutral is one of them. Chassis thickness really has little to do with this.
Should I invest in a 2mm chassis?? Sure, I think you should try it. our track is a school yard, and as such is a pretty bumpy and uneven surface, however they are building a new proper track for us which will have a perfect surface, but i dont know when it will be finished (its a long way off)
Hi Thad
More secure.
spmiz,
The Pro 4 is considered a sedan package
azenis,
Washers only. Any shock o-ring will work.
#6275
Thanks again Thad
What are my options for 2mm chassis? and where to get one? HPI parts availability is pretty minimal here in Australia, so would have to get from HK or USA
The flex thing suprises me.. i thought the stiffer the chassis the better as it would let the suspension do its job better, as with 1:1 cars.
But I guess an rc is more prone to bouncing around as they are only 1:1000th scale when it comes to weight
Would I be better off putting the standard chassis back on in the mean time, and getting some of those washers and the different countersunk screws?
#6276
Originally posted by AdrianM
Hey Thad...do you have a list of what your springs weights are in lbs? We got some springs from you guys a year ago to test with and lost the cheat sheet with the conversions.
Thanks,
Adrian
Thanks,
Adrian
azenis,
#6278
Originally posted by Pit-racer
Thad is slow.
Thad is slow.
#6280
new part?
heres part of the photo of hara in the pits, is that a spool he has in the tray?
#6281
Re: new part?
#6282
What size scews would I need with these washers??
Originally posted by Thad Garner
PUNISHER,
More secure.
spmiz,
azenis,
PUNISHER,
More secure.
spmiz,
azenis,
#6284
Pro 4 Foam outdoor outlaw setup
Hi all...just got a used PRO 4 and wondering where I can find a good foam setup for the car...? I am running it outdoor....some 150x200 track (parking lot) with foams and open motor class....I will be using a Reedy TI 10X3 motor....with 98T spur...what is a good pinion for that size of a track?
Any help is greatly appreciated.....
#6285
Just tested my Pro4 with a spool this afternoon ... IT WAS AWESOME ... why have I not been using this before?? I could get on the power so early and car was hooked round the turns ... definitely the way forward for me ... ! My homemade spool held up well... can't wait for the actual version to be released by HPI...!
