Hpi Pro 4
#5718
well everything really, the diffs were annoying (tried the AE spring trick...didnt work). bevels kept breaking when i used one-way(on the littlest knocks to).
my dad has quit racing now so he has given me his t1r...and i just find xrays to be so reliable
if anyone is interested in the pro4, i can stop the auction early if needs be
#5719
The Evicerator
Erik,
WHERE ARE YOU?
I need to know how to gear!
WHERE ARE YOU?
#5721
Trader Rating: 32 (100%+)
Originally posted by coastaltony
I am changing from 4°, to 2° caster c hubs and I noticed on of the 75122 flange pipe is broken. Go figure!
#5723
what tires u have on?
#5724
I installed 2.0° rear, and 1.5° front pivot blocks, with stock spacing 2mm front, and 2.5mm rear.
I can't get the ride height less than 6mm. Any thoughts?
With the kit springs, I can get my ride height down to about 1mm with the collars all the way up on Rubber Tires.
#5725
Originally posted by popsracer
What SPRINGS are you using?
just a thought
-Dave
#5727
Maybe you need to check your droop too...
#5728
just a question...in situations where i need a stiifer suspension but have no harder springs.....will cranking the preload and leaving everthing else the same give abit of a stiifer sus. feeling? like for emergencies?
#5729
Not sure if adding preload would work, but if you weren't running sway bars then adding sway bars would stiffen the car up.
#5730
Does anyone know the old one-way gear can fit the new version small bevel gear?? If yes I can save the PRP back plate
