Tamiya TRF416 / TRF416WE / TRF416X
#1472
Given that attachments seem to have gone awol at the moment.... here are the last two setups I posted.
Carpet Wars Round 5 (27t Stock)
Carpet Wars World Cup 2008 (5cell Modified)
Cheers
Ed
Cheers
Ed
#1475
Good luck. People have complaints about the car over-rotating mid-corner so be prepared to dial out lots of steering and dial in lots of rear bite.
#1476
So then...
Started out pretty much with Jilles' setup from the DHI, although was running higher roll centres and less rear toe-in to start with. During the meeting, was basically trying to find more steering a lot of the time. Did get too one point where it made the rear of the car too snappy, but managed to solve that by dropping the rear RC a little. The track really didn't have any big braking areas (yes, even with a mod), so steering was pretty key to getting a good lap time.
#1477
balls
I assume wear better ?
#1478
These were designed for the TRF 501X as they are stronger than aluminium ones.
#1479
#1481
JimmyMac. Are those 3racing c-hubs?
#1483
Yeah, 3Racing chubs.
As for the CVD's. I just happen to be digging around some old parts boxes. And found some CVD's and axle parts from when I ran the Cyclone and also my 415 on carpet/foams. Well I had TC4 thick aluminum bones on the axles. But the axle pins do not fit in the outdrivers for Tamiya cars (however they work on HPI/Hotbodies). Well digging around I found I had my RDX steel bones that I ran on my 415. Anyways, the pro3/4 front MIP CVD axles fit the 416 steering knuckles. You only need to add a 0.2mm axle shim to the inside of the knuckle with the kit standard 0.1mm axle washer to the outside of the knuckle. This'll shim the axle just right without excessive play. The RDX steel CVD fits on and lines right up as if you were using a 46mm bone.
It's something I thought I would play with. I was gonna have to give up my 46mm steel bones to my MRE since I need them to sell the car. So I was looking for an alternative until I found some more 46mm steel bones. Everyplace was out of stock (until I found another set this week).
Digging around some more I found some Square 42mm Ti bones that I had for either my 414 or Evo III. They weigh the same as the Tamiya aluminum 44mm bones at 2g. And they don't wear a groove in the axle joint like the aluminum ones do. So those are on the car as well.
#1484
#1485
Square
New Alum. Front Upright
