Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 10-19-2010, 12:46 PM
  #9931
20967's Avatar
Hi everyone.
With the Smoken-Fx chassis I had the same problem. In my the hole were not off-center than the original but the belt most shortened. I slightly loosened the belt and everything went well.
With the new chassis and Spec-R diff in my first indoor race in this season I take the final "A" and I ended up 5th in the overall standings.
Good result if we think that for the first time I raced with the new chassis and the new diff.
Enrico from Italy
20967 is offline
Old 10-19-2010, 12:53 PM
  #9932
Raman's Avatar
Trader Rating: 94 (100%+)
I have the 416 WE..... as far as replacement OEM chassis, I have to stick with the original WE chassis or the 2.5 mm correct?
Raman is offline
Old 10-19-2010, 01:12 PM
  #9933
Raman's Avatar
Originally Posted by artwork
Quote: Originally Posted by Raman Could someone kindly give me the link for the aftermarket gear diff for the 416. Thanks http://www.spec-r.com/specrr2/
Thanks! There was also someone that made covers for the ball diff out of carbon.. Did he ever end up selling them?
Raman is offline
Old 10-19-2010, 01:52 PM
  #9934
Senna Racing's Avatar
No you good get any of the 416 chassis
Tamiya smokem
Senna Racing is offline
Old 10-19-2010, 02:04 PM
  #9935
Raman's Avatar
Tamiya smokem
Thank you Senna! I'm glad I asked.. I was under the impression that the 416X chassis had different hole spacing that would not match up with my WE components.
Raman is offline
Old 10-19-2010, 05:29 PM
  #9936
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Mr_Orange
For those of you that run the smokem fx chassi make sure that the chassi isnt bent like a banana when assembled. We had two chassis that ended up like this and had to file the topdeck quite a bit on both ends and enlarge the front holes in the topdeck to line them up with the bulkhead holes. The chassi seems to be around 0.5mm shorter than stock tamiya one.
Yep same issue here, filed the top deck and everything is ok now
CraigM is offline
Old 10-19-2010, 06:00 PM
  #9937
FK05 lover's Avatar
Trader Rating: 147 (99%+)
So Craig, is it worth getting a Smokem FX chassis?
(yes, I've jumped to a Tamiya)
FK05 lover is offline
Old 10-19-2010, 06:17 PM
  #9938
=FLIP='s Avatar
Trader Rating: 24 (100%+)
YES JIM SMOKEM IS DA S#$T it turns the car from awesome to mega awesome
=FLIP= is offline
Old 10-19-2010, 06:36 PM
  #9939
doriftu's Avatar
Trader Rating: 11 (100%+)
Can you pls post some pics?
Is this a fitment issue with Smokem FX?
Im considering Smokem but after reading this I'm a lil doubtful...
Thanks!
doriftu is offline
Old 10-19-2010, 07:26 PM
  #9940
FK05 lover's Avatar
Thanks Andrew.
Old 10-19-2010, 09:56 PM
  #9941
CraigM's Avatar
Yep I agree, it makes a great car even better
I wrote a review here, it needs to be updated to include the stuff about the top deck needing to be filed
CraigM is offline
Old 10-19-2010, 10:28 PM
  #9942
FK05 lover's Avatar
Thanks Craig..
Old 10-19-2010, 11:02 PM
  #9943
Arahawak's Avatar
Trader Rating: 32 (100%+)
will it affect if after filing and fitted back the normal chassis?
Arahawak is offline
Old 10-20-2010, 03:05 AM
  #9944
CraigM's Avatar
no, you had to do the same on some of the original 416 top decks. I only needed to take a tiny bit off the ends to make mine fit nice
p.s. I've added a post on the tweak. It's pretty self explanatory but I'll try take some photos soon
CraigM is offline
Old 10-20-2010, 03:49 AM
  #9945
DS Motorsport's Avatar
Default Hole distance suspension blocks
Does anyone know if there is a list somewhere which shows all the center to center distances on tamiya suspension blocks?.
If this isn't available maybe someone could be so kind to measure some of the blocks?.
I want to convert my T3 to a tamiya steering system and the tamiya suspension blocks.
I'm currently ordering all the Tamiya parts but first I need to know which blocks I need to get the same trackwidth as I'm currently using.
Thank you.
DS Motorsport is offline
