Tamiya TRF416 / TRF416WE / TRF416X
#9586
Does anyone know the lenght of the titanium piston rod?
#9587
I personally found that Jilles setup to have too much roll as well on higher traction surfaces...Check my setup from Nats...traction was really high and the tires were solaris Hards. To run Sorexs I would just remove the front sweep and a little less camber other then that this setup is pretty good.
Give it a try you might like it...
http://projectgreenracing.com/PGR/Re...X%20Norcal.pdf
#9588
Just giving my 416X a spring clean (yes, it's nearly spring down here ) and I've noticed the swing shafts (front and rear) have quite a lot of play where they connect to the axles. Looks like wear and tear from the pin.
The car is pretty much out of the box, but I don't have 42mm and 44mm spares lying around. Is there a maximum length swing shaft I can use? Is there a preferred/stronger replacement for the standard ones?
Phil.
Phil.
#9589
Phil.
Phil.
#9590
Phil.
Phil.
#9591
wasnt it 42 in rear?
#9594
#9595
Does the swing shafts on the 416X wear out fast? What other 416X parts are easily worn?
#9596
#9599
