Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 07-21-2009, 12:30 AM
  #5956
TryHard's Avatar
Originally Posted by Grizzbob
I imagine they'd have to be the same mounts as the TA05 ver.2 was designed for, which means 2 holes per side. And I'd also imagine that we'd either have to drill the extra holes in the 416's chassis plate ourselves, or Tamiya may offer to sell a new chassis with them incorporated.....
All the 416 chassis plates already have the holes drilled. They use the two outer most holes in line with the current suspension block holes.
Regards
Ed
TryHard is offline
Old 07-21-2009, 12:37 AM
  #5957
Senna Racing's Avatar
has anyone used these do they work
Senna Racing is offline
Old 07-21-2009, 12:54 AM
  #5958
veecee's Avatar
Trader Rating: 34 (100%+)
There's no reason why they do/don't work. But I don't think they offer any performance gains over the standard blocks. Maybe you save a little weight? And some say they are easier to adjust. But I know I'm happy not to spend money on them.
veecee is offline
Old 07-21-2009, 12:59 AM
  #5959
Skitee's Avatar
Yes there's no performance gain from using the separated suspension blocks but it will save you like 2 minutes when replacing a belt, currently you need to remove the inner suspension block when replacing a belt.
Skitee is offline
Old 07-21-2009, 03:14 AM
  #5960
TryHard's Avatar
Something else I spotted from looking at the TA05v2, is that with the new mounts, it would appear that you effectively get two blocks in one. Swapping the left hand with the right hand will give different pin hole widths. Find a pic of the front of the v2, and you'll see the block tops marked with an A and XA.
At a guess, I would figure they'll come as follows;
X
A / XA
B / XB
C / XC
D / XD
E
F
Regards
Ed
TryHard is offline
Old 07-21-2009, 03:18 AM
  #5961
CraigM's Avatar
X
A / XA
B / XB
C / XC
D / XD
E
F
Regards
Ed
nice! I assume the FR block would be a lot harder to bend too
CraigM is offline
Old 07-21-2009, 05:14 AM
  #5962
veecee's Avatar
X
A / XA
B / XB
C / XC
D / XD
E
F
Regards
Ed
Right on the money Ed!
X
A / XA
B / XB
C / XC
D / XD
veecee is offline
Old 07-21-2009, 06:20 AM
  #5963
syndr0me's Avatar
Trader Rating: 32 (100%+)
If they don't bend as easily, I may be in lurve!
So I've been practicing with the car at 1425g in preparation for Vegas, and it feels a bit unsettled. Maybe softer springs all around since there's not as much weight to transfer around? White/Blue seems a little twitchy.
syndr0me is offline
Old 07-21-2009, 06:24 AM
  #5964
Originally Posted by Stein Tumert
They look great ! But holy crap man !! $29.00 .... NO FRICKIN' WAY MAN!!!
John St.Amant is offline
Old 07-21-2009, 06:30 AM
  #5965
i used to use blue/yellow but changed to the HPi spring silver/gold and the car is soooo much better
this is on asphalt though
i like the seperate mounts , may be ordering those
sidecarphil1 is offline
Old 07-21-2009, 07:50 AM
  #5966
RC MARKET's Avatar
Trader Rating: 12 (100%+)
New Suspension mount
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-ta-54174.jpg   Tamiya TRF416 / TRF416WE / TRF416X-ta-54173.jpg
RC MARKET is offline
Old 07-21-2009, 08:31 AM
  #5967
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
They will also change the flex characteristics of the chassis. They should allow the chassis to flex a bit more at whichever end you put them on. Could be good to get that little extra steering or traction.
Randy Caster is offline
Old 07-21-2009, 08:41 AM
  #5968
Hard to find....
1XA ?
Makes fixing a lower arm faster too.
Old 07-21-2009, 08:42 AM
  #5969
Ricky/C's Avatar
So I should stay clear of these if I dont want more flex?
We run foam on asphalt and I'm not too sure what more flex in the chassis will do???
Ricky/C is offline
Old 07-21-2009, 08:44 AM
  #5970
Notice that if they are swapped side to side that you have 2 different settings.
IN or OUT.... Pretty cleaver eh?!
