Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 12-07-2007, 05:04 AM
  #451
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by gizmo
No it doesn`t come with the aluminium uprights.
hard plastic ones are provided with 10x5 bearings
also the new wheelaxles are a bit longer.....
and we can`t use the front bridge suspension. for now
@ rc-market
your request.....
greetz
C.
Thanks your detail post !
RC MARKET is offline
Old 12-07-2007, 05:31 AM
  #452
Fastforward's Avatar
Originally Posted by syndr0me
I'm thinking more about using one or two to secure the pack, not put a bunch of weight down low. :-)
If your weights won't work you could use model airplane plywood and cut and shape the pieces to your liking. The 416 sure looks nice.
Fastforward is offline
Old 12-07-2007, 05:33 AM
  #453
KoE
KoE's Avatar
yeaaa....santa came early this year ima leave all the measurements to gizmo...ima have fun with the blue bits for a while before assembly. Tamiya Malaysia rocks :-)
KoE is offline
Old 12-07-2007, 06:45 AM
  #454
miccal's Avatar
Trader Rating: 23 (100%+)
The layout of the center shaft is like the new Xray T2008. I have heard that there is an issue with the T2008 where the battery touches the pinion and spur gears.
Gizmo, can you perhaps show a picture of the 64P and 48P gears setups with a battery installed?
Also, is that 48P spur gear you have installed a special one, or is it just a regular one? Did it fit without issues?
miccal is offline
Old 12-07-2007, 07:09 AM
  #455
Miccal
That a normal xenon spurgear on the blue screw car other car
RW spurgear on the titanium screw car
It fits without issues.
but will do a test tonight,or ask mr Vd Hagen his car is already in race mod!!
koE. don`t have a car here..(ya I know 5 cars and not 1 when you need one) (-:
So Ill will measure it tonnight.
@Cato54 yes they come with alu cvd all around,42 steel will fitt with the first type one way axles(53590)
regards
C.
gizmo is offline
Old 12-07-2007, 08:03 AM
  #456
mac853's Avatar
Hey guys, why haven't got anybody to asking for spool?
The idea i had made before didn't work?
mac853 is offline
Old 12-07-2007, 09:30 AM
  #457
RC MARKET's Avatar
Miccal
regards
C.
415 spool fit to use in 416 ?
Old 12-07-2007, 09:48 AM
  #458
If the inner diameter is 24mm then it is the same as 415. I test mounted the pulley the other way around on the spool and fits within the bulkheads of a 415. Maybe this will work as a temporary fix on 416 as the pulley is only supported by the screws.
Mr_Orange is offline
Old 12-07-2007, 10:19 AM
  #459
Originally Posted by miccal
OUCH $498
I think there is a pallete missing from Tamiya's warehouse
redbones is offline
Old 12-07-2007, 10:43 AM
  #460
credit to mr orange..
sorry guy`s for the dirty spool, it was the only one i could find in a short notice
sleeves need remodeling.
C.
gizmo is offline
Old 12-07-2007, 12:59 PM
  #461
Racing4Evo's Avatar
Gizmo- What the heck? What spool is that?
Racing4Evo is offline
Old 12-07-2007, 01:43 PM
  #462
miccal's Avatar
Originally Posted by redbones
OUCH $498
And that one has already gone. The seller has listed another.
miccal is offline
Old 12-07-2007, 01:53 PM
  #463
veecee's Avatar
Trader Rating: 34 (100%+)
gizmo, any chance you can post a scan of the back page from the manual so we can see a list of spares/option parts? Thanks mate.
veecee is offline
Old 12-07-2007, 02:19 PM
  #464
HPZ
Hello Gizmo i was wondering what size spur are you using for the car with the Xenon spur?
And what are the suspension block order, so far from what i've seen, starting from the front of the car is 1B then 1XB . What are the rear block? I am assuming they are 1A and 1D. If so, do the standard (plastic) rear uprights have any natural toe angle?
Thank you
HPZ is offline
Old 12-07-2007, 02:44 PM
  #465
miccal's Avatar
Thank you
I assume it is 1B/1A front, 1XB/1D rear.
miccal is offline
