Tamiya TRF416 / TRF416WE / TRF416X
#4486
That particular lipo is too tall to fit under the top deck. It's in a bitty design tray, which weighs 40g
I miss 10.5 .
Just a friendly word of precaution.
You need to tuck in that sensor lead. Its going to get yoinked!
That wouldn't be a good thing either, trust me!
The battery is offset like that to balance the chassis out . When its in the regular spot it takes more weight to ballence. Personally I like mine in the correct spot. They are also slowing down the polar moment. The Thunder Power 5000mah 40 c pack fits right in there. I perfer to keep my electronics protected instead of hanging the battery and wires out where they can get dammaged.
#4487
This might been ask before, how do you actually balance weight the car left-right? And from the pic that CraigM posted i can see the steering system has a carbon brace on top instead of blue alum stock brace that attached to the upper deck? Whats the purpose of it?
#4488
Thats what I did, it's not too hard
I want to shorten the sensor but I hear it's a real b!tch to do, so I just made it into a pretzel for the photos. To be honest I cant tell the difference between the 28c and the 40c SMC packs, so I might end up ditching my 40c pack and going back to using the PPD tray with the smaller lipo to keep the weight centred
#4489
Just out of curiosity, how did you come about this information?
Moreover, do you know what the Airtronics model number equivalent would be?
Thanks, Chris
Viktor Wilck is my r/c friend so he told me .
Thanks, Chris
#4491
A lot of people in certain threads have reported that the Orion packs lack punch, which would be why you felt a difference when switching from Orion to Thunder Power. It was not the change in C rating for you, it was the change of brand. Craig is talking about different C ratings in the same brand, SMC. So no, you cannot guarantee it.
If you cant tell the difference .. I would suggest that you do not have enough grear on it. Or maybe even you have the timing down or punch turnd down or maybe even all the above. I had run my 3800 orion packs last week and the only thing I changed was the 40c thunder power battery . OH MAN WHAT A DIFFERENCE! Perhaps maybe go up a couple teeth on the pinion and try a before and after . You should be able to notice a big difference. I guarantee it!
#4492
A lot of people in certain threads have reported that the Orion packs lack punch, which would be why you felt a difference when switching from Orion to Trackpower. It was not the change in C rating for you, it was the change of brand. Craig is talking about different C ratings in the same brand, SMC. So no, you cannot guarantee it.
The 38's will be perfect in the dirt!!!
#4493
By the way, are those pics of your car?
#4494
#4495
Wasn't the capacity and the C rating kinda related .. Like if you had more run time it affected the relative C rating . SMC onlt care to maximize case size rather than weather or not it fits in anyones cars or the conectivity ... but that water under a different bridge.
NOW... my car had the wandering issue more than ever today. I took it off the track, stuck it on the setup station, centred the servo and it was way off. I was like, "WTF???", then tugged on the servo saver and I could move it probably about 20 degrees each side of centre without much effort. I stuck a kimbrough saver on and problem solved, no more wandering and even after having a few hits and steered much more consistenly. It was after that I realised that my servo saver has had that issue for half the time I've had the car, I just always thought it was getting tweaked
#4496
TITC 09
#4497
Excuse me
Could anybody tell me which size of HUDY arm reamers and turnbuckle wrench fits any TRF cars, please?
Best regards
Best regards
#4498
http://www.rctech.net/forum/4939642-post523.html
I haven't tried it yet, though.
#4499
I don't what the exact size of the arm reamers was, but with the turnbuckle wrench I recommend the Tamiya wrench itself, it's the best fit there is. I know some people using wrenches from other brands, but the all didn't fit as good as the Tamiya one, and as a result the turnbuckles were damaged and the blue went off. Which is something you want to avoid
#4500
I came across this tip about the Tamiya servo savers in the IFS thread:
