Tamiya TRF416 / TRF416WE / TRF416X
#2659
R/C Tech Elite Member
If you are using tire warmers, give the tires a little more time to cool off. You could also try enlarging the air hole on the wheel a little bit.
If the problem continues, I'd be glad to help with the setup, but I think the tires will be the biggest change you can make.
#2660
Hi guys, my LRP vector 10.5 turned up today, im gonna run lipo with this motor on my lrp sphere tc spec, what would be the recommended pinion/spur for carpet and tarmac for my 416...??
also i keep reading about people having problems with the above speedo, how many people have blown these things, ive yet to run mine and just praying mine stays alive..
thanks in advance
thanks in advance
#2661
thanks in advance
thanks in advance
the LRP 10.5 motor recommends a 5.0 FDR for a "large" asphalt tracks. since your using an LRP motor..... check the package, they have an insert with gearing recommendations.
#2662
thanks in advance
thanks in advance
Worn out tires will do pretty much exactly what you described. If you are happy with the car at the start of the run, just try a fresh set of tires.
#2663
K guys can someone explaning using the upper links to change roll centers?
I know u can raise the roll center by adding shims under the suspension
blocks. so to lower it roll center do u lower the spacer under the ball end
on the top suspesn links?
I jsut tryin to get an grip on it. had an rough race last weekend
could set up. thanks
#2664
To lower the roll center, add spacers under the inner upper arm links. Adding spacers under the outer upper links raises the roll center.
#2665
At the moment all i know is that we will be making a track in the carpark where the surface is smoothish and also pits will be indoors in one of the buildings next to it. We will be testing the surface/track soon but idont know when exactly. Once i find out more i will let you know.
#2667
aye, is quiet... still, all going well my end. Took the car to the local track for the first time this past weekend. It's quite tight and technical, but good fun. Ended up dropping the roll bars down to soft to get the steering up... worked a treat. Still some more work needed to get it spot on, but as it's now my local, hopefully won't take long to iron it out
Regards
Ed
Regards
Ed
#2669
Would that be bashley?
I think i am spending too much time on the Tamiya forum dont you think Ed hehehe
Had a go with a 416 on tues, rear end was a little too bolted, but i think it was kit setup, oneway and i presume 3 dregrees toe?
Not bad at all though.......one phi prev sold!!
Regards
Ed
Regards
Ed
#2670
thanks in advance
thanks in advance
