Tamiya TRF416 / TRF416WE / TRF416X
#1936
The 2.5 chassis is good on higher bite carpet, but i have found the flex of the 2.25 helps in low grip or on asphalt. Last year at reedy i used a 2mm and it was great! I have actually used black rubber o-rings under my upper deck to get the car to flex more at my local track. It was a little more "loppy" but very consistent and provided great traction. Keep in mind this was only for low grip situations, such as the begining of a night racing or new carpet. I had even noticed in one of the pics from the last event Viktor had removed the steering post brace to get a little more flex out of the car.
#1937
Super Moderator
To Quote from the Team Orion bumf...
I use a Carbon 3600 pack, and have to use ~220g of lead to get it up too weight. I have 140g mounted on the pack, then put the other 70odd grams on the car elsewhere.
Personally, I would go for a Orion 3600 or Schumacher Core 5000 pack over the 4800... the 4800 is a little bit of old tech now (if it can be called that ), and the 36 and Core5000 have much more punch.
HiH
Ed
HiH
Ed
#1938
Will the shell of my msx fit the 416 body posts.is it a direct fit or am i going need a new shell??
#1939
some TRF416 Spool arrived ready to send !
#1941
#1942
Actually, I think the new SMC hardcased packs are the most impressive I've seen(or run for that matter, first LiPo I've tried that shows ALL of the punch of the best NiMh's I'e ever had, though I'll admit I have not tried the Orion 3600, but I have the others & the SMC feels better & my lap times seem to bear it out), & I believe their 5000mah one is similar, weighs in at like 286g. It's definitely one to consider.....
It seems like SMC's cells are doing very well on the voltage front, and cycle life has been decent as well. If you heat them up a little bit, the voltage is quite a bit better, with no detriment to the pack. I've had my share of disagreements with the SMC folks, but there's no question those are the cells I'll go with next, especially if it's a big race allowing LiPo. The only other one I'm really curious about is Tekin, because I suspect they're going with a cell manufacturer I'm very fond of.
#1944
#1946
#1947
Hi people,
I’m looking for some parts to a 416 and I find that the suspension block 1C has two different references: 51067 and 54536…
Can anyone confirm witch is for the 416 and can someone give me all the references of the 416 suspensions blocks please?
Thanks in advance.
Thanks in advance.
#1950
rcchamp,dinballrc,rcmarket,stellamodels,rcmushroom . try those
