Picco P7 Evo 2
#241
#242
Driving style has allot to do with run times...If you are a point and shoot driver, you will get less run times than someone who has a smoother trigger finger..before you go freaking out about your low run times, try going our for practice and instead of jamming the throttle open as soon as you break out of the turn, try rolling the throttle to about 3/4 and entering the next turn at a slightly slower speed..Try different variations to see which works better for you and time your tank! I have seen drivers get up to 3 minutes more run time by learning how to be smooth and fast, and not just fast
#243
Hey guys I just bought this engine (p7r) and I was wondering which mounts are you guys using? this engine seems to be sitting a little higher than all of my other engines. Would any of these mounts work:
http://www.amainhobbies.com/product_...nts-Mayhem-Pro
http://www.amainhobbies.com/product_...ull-Start-Blue
http://www.amainhobbies.com/product_...Mayhem-Pro-RTR
http://www.amainhobbies.com/product_...ount-Long-43mm
#244
you need a NON Pull start mount....you obviously are coming from a RTR ? what vehicle are we talkin ? Mayhem i can assume ?
#245
My friend has a picco p7 evo 2 that is new after breakin and he cant get it to run right. it is his second one, the first ran great this one never seems to make power. We have tried different pipes and tuned till the cows come home. I runs ok but not to the standard of other evo 2's. Last week it developed a low end bog after a bump from the b main to the a main, the bog came during the a main. the temps after that main was about 215f. help please
#246
is the carb sealed ? these motor's have a tendency to leak between the composite and alum on the body of the carb...seal it up and see if that cure's the issues...i bet you it will.
