Trinity G4 - Team Magic G4 E-Type
#2056
Would putting a lower shore of foam tires in the rear make it hook up more? I'm running 42's in front and rear.
#2057
If you don't mind buying tires a little more often, I'd say definitely go lower. Depends on your track surface and temperature.
I myself normally run 37 shore, front and rear in Houston. Its like a 95 to 100 degrees on average racing days.
#2058
ideal compound is 37 all around, i have seen racers go down as low as 35 on nitro touring cars at some races. i myself run 45 front and 42 rear where we run at the lot and put on 37 when we travel to the races. basically when you make the rear softer you increase traction, however if it is too soft you will get a push because of the chassis roll.
#2059
I mainly race on a parking lot in Kansas City, I think I will try the 37's. Thanks for the help.
#2060
Trinity Reflex NT
Hi guys,
Is the bearing sizes the same for the Reflex for our car? Im trying to order so good quality bearings.
Sami
Sami
#2061
I know that the bearings around the diffs are the same size as the reflex, but not sure about the rest, I have a reflex and a g4 and could check.
#2062
Bearings
Hi RcRacer14,
Could you please check, the bearings you need on the G4 are:
5 x 8 x 2.5mm ( 2)
5 x 8 flanged bearing (2)
5 x 10 x 4 (4)
5 x 11 x 4 (4)
6 x 10 x 3 (2)
6 x 12 x 4 (4)
10 x 15 x 4 (4)
12 x 18 x 4 (4)
Sami
5 x 8 x 2.5mm ( 2)
5 x 10 x 4 (4)
5 x 11 x 4 (4)
6 x 10 x 3 (2)
6 x 12 x 4 (4)
10 x 15 x 4 (4)
12 x 18 x 4 (4)
Sami
#2065
ttektek, I just finished checking and yes all the bearings on the Reflex are the same size on the G4.
#2066
Spy Shoot
Nick just release this pix...
#2067
Yes, we have just received the picture too... And they will also have a new bumper for Lola VDS body.
#2068
is that pic on the team magic website or forum?
#2069
any idea when this steering system will be available? I might need to reconsider which new Kit I purchase
#2070
dino.tw: is that the prototype steering that team magic is working on? looks like the railing is still there huh... i wonder how it works and when it will be out in the market. my steering in my evo is okay so far... i give it a buff once in awhile with a metal polisher using a dremel and it really helps remove the groove on the railing!
