Tamiya F103 Forum >
Tamiya F103 Forum
Like Tree9Likes
Tamiya F103 Forum
Old 06-18-2010, 03:24 PM
  #1321
GasGod's Avatar
That car SUCKS---
in a good way!
GasGod is offline
Old 06-19-2010, 02:29 AM
  #1322
Gday im looking at buying a tamiya f103 or a f104
can anyone one out there give me a insight as what would be the better
model to race competitive ive spoken to a few pepole about it and the word is
the f103 is better for racing but looking at both spec sheets i reckon the f104 sounds better any suggestions
tankmiester82 is offline
Old 06-19-2010, 02:52 AM
  #1323
gtfour93's Avatar
Trader Rating: 22 (100%+)
Default R1wurks Dual fan setup
This would be perfect for GTP/LMP bodies. Nice product!
gtfour93 is offline
Old 06-19-2010, 08:07 AM
  #1324
BadSign's Avatar
Trader Rating: 15 (100%+)
Originally Posted by GasGod
That car SUCKS---
in a good way!
Unless you're behind it- then it blows.
Man, think of the front wing failurs behind that thing.
BadSign is offline
Old 06-19-2010, 04:30 PM
  #1325
oldnwise's Avatar
Originally Posted by R1wurks
R1wurks New dual side by side 25x25 fan kit. this fits most F1 cars, some 1/12 pan cars,4x4 short coarse trucks & 1/10 on-road touring cars
Features:
- Fully adjustable clamp style design
- Pre-wired dual fan (plug & play)
- Dual 25x25 high rpm fans 15,000rpm,a total of 7.0cfm of airflow
- fits 540 & 550 can size
MSRP $35.00
Please pm or email us more information at [email protected]
Waste of money for an F1 car and brushless motor. My brushless is only mildly warm after 5 minutes of racing.
Agree with previous posts that it would look ugly on an F1.
oldnwise is offline
Old 06-19-2010, 04:34 PM
  #1326
oldnwise's Avatar
If you are racing check with the members at your local track what works best for the track. The weight distribution of the two cars is totally different and particularly for the F104 what works at one track may not work at another.
oldnwise is offline
Old 06-20-2010, 12:35 AM
  #1327
kneedeeppow's Avatar
Default RC RBR
Here is some pictures of my Redbull Racing F1. Its a F103,unsure of what sort of body it is,iy came with a parts lot i bought.
Attached Thumbnails Tamiya F103 Forum-rbr1.jpg   Tamiya F103 Forum-rbr2.jpg   Tamiya F103 Forum-rbr3.jpg
kneedeeppow is offline
Old 06-20-2010, 06:53 AM
  #1328
The F103 was designed with rubber tyres and asphalt in mind.
The F104 with foams and carpet.
In my home track (large outdoor asphalt), my 103 runs as well if not better than the bunch of 104's of the other guys.
prorace is offline
Old 06-20-2010, 11:18 AM
  #1329
That is the Benneton body
InspGadgt is offline
Old 06-20-2010, 11:20 AM
  #1330
Actually the F103 was designed with foam tires. The rubber tires did not come out for the F103 until several years after it was first introduced. Pan cars in general do better on a foam tire than on a rubber tire if given enough grip and both cars are a type of pan car.
Old 06-20-2010, 11:23 AM
  #1331
If the grip is high enough to run foam tires...the F103 being wider and shorter wheel base will be quicker through the corners. But if grip is low and rubber tires are being used than it could go either way. At our track the rubber tires made for the F104 get better grip so they generally do better than the F103 on rubber tires.
Old 06-23-2010, 02:57 AM
  #1332
Sir Tamiyalot's Avatar
Hi, what brushless motor (turns) would you sugest for a controlled class? Is 17.5t too fast? We will be using f103's & f104's on asphelt with rubber tyres.
Sir Tamiyalot is offline
Old 06-23-2010, 03:37 AM
  #1333
Depending on the size track a 17.5 may be fine...but to be a more controlled class maybe look at a 21.5 from the VTA series or a 25.5.
Old 06-23-2010, 04:33 AM
  #1334
westy1969's Avatar
We run a f1 17.5 competition, the speed is great. around 70kph.
The cars that we run are; F103, F104, TRG109, 3R-F109, HPI F10, Corally, Selfbuild.
The tires that we use are from Ride and TRG.
Here is a video i posted earlier;
+ YouTube Video
westy1969 is offline
Old 06-23-2010, 05:26 AM
  #1335
Guest
Default F103 Body ??? Has anyone seen this before ?
Hi, f103ers,
I just started out with Pancars and found a F103 together with this body:Tamiya F103 Forum-img_2680.jpg. Previous owner could not comment on it...
When searching I could only find the F103 with the Audi R8 Spyder type body(58247), not this Audi R8C closed body type.
Is it another brand in the end ?
I want to know what I got before I wreck it
ideas, anyone ?
cheers, Stefan
stefka is offline
