I NEED HELP!!!
I NEED HELP!!!
I just started using the mamba max system about a month ago. The first three weekends of running it was ok, all i had to deal with was some tyre problems and stripping gears,i got over those. But now the lock nut on the pinion on the motor keep backing off i changed the pinion and the same thing happened.Can some one help me out wit this problem?
get a high quality allen driver for your pinion set screws. if you are using the little "L" wrenches that come with the gear or the kit, they strip out easily and won't let you tighten that screw down fully.
dynamite, racers edge, team losi, team associated, MIP, hudy - they all make quality allen drivers.
Use a little bit of thread lock...
i tried a thread lock and it still came back and when i tried adjusting it again on the first one it was in the tighten position and the key is now slipping
