GM Brushless
#1171
Thanks for the info Martin.
Some UK shops have the new motors in stock already. Do you know how long before the Gen 2 speedo's will be released and available to buy?
Many thanks
Oli
Many thanks
Oli
#1172
no exact releasedate yet
but I guess around jan 2010
#1173
correct
#1175
Hi!
Last day I set gm's software for my friend without problems
on very small netbook with winxp.
Before instal try turn off if you have antivirus software, check if your
windows is up to date, then download:
- soft for GM:
- usb driver:
Unzip usb driver, launch exec file, then should start unpacking, and
ask something like that "install usb driver ble ble", just use YES button or NEXT.
When you connect usb device to pc, you should see some info, that
windows found some new device
Install GM software and try use it.
Older software for USB device is a little bad for new software in GM esc.
Try do it again.
Regards!
m.
- soft for GM:
- usb driver:
Try do it again.
Regards!
m.
Fantastic, thanks very much for the help
#1177
Yes everything works and i can transmit data from the GM120 to my PC and save it.
BUT
I am having trouble loading the special 13.5 Lipo program and sending it to my GM120.
I have read you should change the .TXT file to a .GDA file and upload it.
But when i go to upload it can't see .GDA files, it can only see .TDA files, but if i go to file open it is the other way around (it will only see .GDA files and not .TDA files).
So my first question is do i save the .TXT file as a .GDA or .TDA and do i get it into the software by opening it or uploading it.
My second question is you also need to bring in your current settings aswell, so do i just do the same thing again once the other file settings are on the screen.
My third question is do i need to register the software to be able to send the data to my GM120. My problem is my Laptop is not connected to the internet, as i have downloaded the software in work then installed it at home.
Sorry to be sounding stupid with all these questions, but i am just trying to get my head around it all, and i think it may take me longer than others
Thanks in advance
BUT
Thanks in advance
#1178
BUT
Thanks in advance
BUT
Thanks in advance
2. Start your Genius program, In your Genius sw, open this .gda file ("file open" etc). Connect to the ESC and you can load the settings you have just loaded from the .gda file to the ESC (note: you need v7.2 in the ESC if you want to use martin's 13.5T LiPo program from some pages back)
3. No, you do not need to register the Genius software (but you should)
#1179
1. change the file extension to .gda
Sorry but this now leads me to 2 more questions
1. when i go to send this data to my GM120, an error warning comes up saying: 'Temperature protection is deactivated Send Data anyway (loose warranty)?
Is this normal?
2. Once the program settings have been sent, do i have to choose a particular mode on the GM120 via my transmitter, for this program to come into effect, or will it automatically run this program when i turn it on?
Thanks in advance
#1180
1 - this means that you have switched off the temp protect! it is in reserved. If your value is "odd" then temp protect is off, if it's "even" then it is on.
2 - nope, what ever you send it, it will run.
#1181
Hi,
As i said before i bought a 120 to run in 9.5T stock competition here in Portugal.
We don´t know yet if it will be 9.5, 10.5 or 13.5
I currently have a CS 9.5T so i will start the practice with this motor.
At the moment i´m also looking for batteries.. i already bought a LRP 5300 40C, but i don´t know if i should buy more or should i wait for something new (more power ?).
Since I will run stocks, with the GM 120. Should i wait for the new batteries Or should i buy one more LRP ?
It´s difficult to start buying in this time of the year
#1182
you should buy better batterys
#1184
I need help please.
I was racing at Carpetwars the weekend just gone. I was using a GM120 with a Speed Passion 10.5. Through saturday practice the SP was coming off at around 45-52 degress. But then i put a GM motor in. I didn't change my gearing or the esc settings and the GM motor MELTED, yes MELTED after just 4mins. So, with that in mind, what are the differences between the GM and the SP 10.5's and what do i need to do differently to the esc or gearing, when using a GM motor, to stop another Hiroshima happening under my body shell?
#1185
I need help please.
Which program or settings on your GM120 + sw release?
