GM Brushless
#946
I believe that is true, yes.
For me, probably easier to try and make a 90/120 fit!! Rather than get a 95, then send back for software.
#947
I really do love this esc! But last weekend it straingly failed in a race after 70 seconds of racing 10.5 in my TC. It was fast as usual with my GM 10.5 but then it just rolled to a stop. Very strainge! I checked everything over and yes it was the esc. Ive heard this happen to this esc before. I understand that my 120 is in germany now.
Whats general practice for this kind of failure in germany GM? Will i get a new replacement?
Also just wondering if it would be possible to have my esc updated with the latest firmware aswell.
Ive really missed my 120 this weekend at the UK national. I could be barely do 4 1/2 minutes with an lrp esc on 5cell mod. Reminds me what a great esc it is!
-Jonny
-Jonny
in case of failure a factory reset works wonders
If you are hardcore you can take off GM120 or 90 from case,
but you can look for this:
http://shop.graupner.de/webuerp/servlet/AI?ARTN=2898.12
GM-GENIUS 95 im Schrumpfschlauch f. 1:12 Order number 2898.12
http://www.hobbydirekt.de/Graupner/R...2::114787.html
never take a 120/90 out of it's case
the fets are GLUED to the case and you will rip them off the curcuit board when trying to take the case off
yes it's updateable to fw7.2
#948
Hi Martin!
safety for overheat, if ESC got high temp normally shut down, but
owner can set it off (temp-cut) and next question is simple
what GM tech dept do if I "broken" esc with temp cut set off and send it
for reclamation or repair ?
Regards!
m.
ps: broken = fired mosfets
ps1: about take off gm 120/90 from case I wrote hardcore, GM 95 for E12 is
prepared for this class
Regards!
m.
#949
set reserved back to 16 before sending it
#950
Anyone know the return procedure for firmware update?
I have the address in Kircheim but as no one from Graupner can be bothered to talk to me or call me back after a day of trying I'm stuck as how to proceed as I believe there is a charge.
Any help would be appreciated.
#951
i think the charge is 20 euros but not sure how you would go about doing it
#952
Hi martin,
Can I have a good starting point setup for the GM120 with a 6 delta sensored ?
It's for a big track, when we need runtime...
#953
run sensorless, much more efficient and more torque
#954
okay
and do you have a good starting point with it ?
#955
With Sensorless things are so much more simple, and personally i nearly always prefer the "feel". The amount of torque can be a little difficult to get used to, especially on a small track, but for me, once i got used to it, I much prefer it.
As Martin also says, it is better for runtime as well. Sensored can sometimes have more top speed at the end of the main straight, but there is only 1 main straight usually - where as you benifit from the torque coming off every corner. I think you essentially just run it on std profile, setting 2 or 3 and then drive! I just gave mine to Chris to setup when i first put it in the car!!!
#956
lipo or 5cell?
#957
5 cells
and after with Life...
#958
standard mode 2 with 3.6V undervoltage cutoff (4V for life)
#959
ThX Martin !
#960
