GM Brushless
#721
I am interested in getting a GM 10.5 motor for the Tc national here in the UK BUT ive heard rumours that they will lack in performance and not run very well when with a Nosram Esc and that they are really made for the GM esc's. Also i have heard that they are meant for Esc's that have variable timing like the GM or Stock spec esc's and dont perform aswell with an esc without this feature like the Nosram ISTC etc.
Is this true?
Could someone help me as i need a motor very soon and was interested in the GM , i dont know now though?
Is this true?
but the motor ofcourse also works with a nosram speedo
gm stock motors are absolut #1 choice amongst racers here in germany with over 95% of the drivers at the last german outdoor national used the GM motor
Hey Martin hope were all keeping you busy good job.
Could you tell me on version 1.3.6 where it has opened up the special tab which has the switching point rpm, and timing 2 & 1 adjustable settings, what does this actually change and how and which is the best settings to run on with GM 6.5 with 12.5 rotor.
I am already running in mode 8 over 3 and running on a medium sized asphalt track geared at 7.0fdr
I am currently running switching RPM @ 25,000rpm
Timing 2 @ 120 & Timing 1 @ 80
Many Thanks
Paul
Many Thanks
Paul
don't mess around with special settings ... most / nearly all of the teamdrivers don't do so too
it's far more complicated than what it looks like and you will most likely mess up more than you gain
actually we never use 7 anyway
either mode 6 copied to mode 3 for 5cell racing, or 8 copied to mode 3 if temperature is too high
#723
does the Genius 90 come with a sensor cable ???
#724
yes it comes with an adaptor but I'd suggest to order 2894.4
#725
what is that martin ??
found it
found it
#726
unlike the pic the sensorwire is all black
#727
that is a sensor wire for motors to speedo not just a condersion wire
cool ordering one of those also
thank you martin
thank you martin
#728
The conversion cable and sensor cable that martin has posted Connect to all (as far as im aware) sensored motors. The gm motors have the common sensor plug the same as lrp and novak. It is only the speedcontroller that is different
#731
hey guys,
Ive downloaded the usb port download as above in the other post.
Is there anything else that I need to download>
The instructions say AS Genius tool, but im unsure on what else i need
If someone could help then it would be much appreciated
Chris
Chris
#732
http://www.graupner.de/fileadmin/sof...up_V1.3.6_.zip )
For older soft in ESC try use this:
http://www.graupner.de/fileadmin/sof...p_01_01_05.zip
it works with 4 mode esc and 8 mode soft version 4.9 (frimware=19, I have this one)
All info there:
http://shop.graupner.de/webuerp/servlet/AI?ARTN=7168
Hope this helps!
m.
#733
ok my girlfriend has ordered my new GM120 for my birthday
BRING ON THE SPEED
martin what do i need to change first to progam this or do i just try the factory settings first ???
cheeRS phil
BRING ON THE SPEED
cheeRS phil
#734
and try mode 6 background copied into mode 3
#735
hello martin
is the difrence in program 6 to 3 and 8 to3 the same as normal 6 or 8.
and wat is the difrence from normal 6 or 6 to 3 in driving feeling
greetings marcel
greetings marcel
