GM Brushless
#2567
In GM land, 'boost' is set using the 'fixed timing' variable. So the two are the same thing.
There is only one type of timing advance on the GM (as of v13), which is turned on or off using the 'high speed timing' option. The amount of timing advance is then set using the 'fixed timing' variable.
#2571
Am running profile 1 and 2 with a 4.5t
the default is 30 in fixed timing software version is 13.1
Is there any boost enabled ? or does it require the high speed timing option to use that?
#2572
I just wont to run 30 degree of timing nothing else
#2573
To disable boost just untick High Speed Timing. easy as that.
#2574
Brushless=1
Sensor=0
Car=
Place=
BarCode=
Comment=
Motor=
Pinion=0
MainGear=0
InternalGearRatio=0
TireDiameter=0
MaxRotationSpeed=27
MaxCurrent=145
[GeniusData]
StartAmp=150
AmpLimit=200
Turbo=1
BrakeMin=20
BrakeMax=100
AutoBrake=0
FullBrake=100
ABS=0
RPMLimit=13
Polzahl=2
Frequency=9
Reserved=16
MaxReverse=30
Softgas=50
PowerCurve=11
Autogas=0
Switch=6
OnAfterUSB=1
Timing=0
TimingWith=2
[GeniusDataAdv]
Reserved1=141
Softbrake=100
FullThrottle=22545
NeutralPoint=15638
FullBrakePoint=11140
NeutralPointWidth=80
ControllerMode=2
VoltageCutOff=250
PWMStartNoSensor=128
LimStartNoSensor=30
EffectNewBrake=150
Reserved2=9
SwitchPointRPM=125
MaxTiming=25
FixTiming=6164
Timing2=120
Timing1=90
CutOffTempContr=175
MaxRPM=27
Firmware=116
MaxCurrent=145
CutOffTempMotor=140
MaxESCTemp=76
MaxMotorTemp=0
ActESCTemp=19
ActMotorTemp=0
EEProm=137
ActVoltage=0
CurrentOffset=4
MaxTempContr=80
MaxTempMotor=92
AbsMaxCurrent=177
DisCapacity=10291
CurLimit_Temp=20
TimeToFull=175
CorrectCurLimit=64
MaxCapacity=40000
VoltageCorrect=180
MaxVoltage=160
Telemetry=129
Poles=2
Pinion=25
MainGear=89
TireDiam=64
InternGear=25
OverallGear=7377
Reserved4=3
HighByteParity=21
LowByteParity=55
here are my settings
#2580
The first thing you should do is upgrade to v13 firmware. Most (maybe all) of the advice given is for v13 firmware, which is substantially different to the previous firmware.
The second thing you should do is read Martins v13 guide and start with his profile. That will get you most of the way there.
