GM Brushless
#2536
Unfortunately they don't stock it anymore.
It sucks that amazon germany wants only 44eu for it but they won't ship out of Europe while most hobby retailers I can find (which don't ship outside of the EU anyway) want 80-100eu for it.
#2538
Powercurve
Hello,
In Genius Tool GII V. 1.6.5 for ESC GM120
"The Powercurves are only in function if Timing with Sensors is set to +30°"
Is this thrue ? The most drivers I know donīt set it on +30°. Powercurve is set on 9 (10.5motor). Whatīs the difference between timing is set on +0° or +30° ?
Someone good setup for 10.5 on asphalt outdoors ?
Tia, evolution
Tia, evolution
#2540
GM75 overheating on large track where as the motor is very cold...
Do I go up in rollout?
#2541
#2542
Read the v13 guide from Martin Hoffer. Use his settings file and just tune the settings he advises (amp limit, fixed timing and switchpoint).
http://www.rctech.net/forum/7908081-post1851.html
#2543
Hello,
Tia, evolution
Tia, evolution
For 10.5 on a medium sized track (40m straight) I run:
15k switchpoint
80A current limit
18 Fixed Timing and 6.7 FDR with LRP x12
22 Fixed Timing and 6.7 FDR with Speedpassion v3
I use the Variable Dependence Timing as it keeps the motor cooler and allows higher timing settings.
#2544
If you're using the v13 firmware with High Speed Timing enabled, the power curve setting doesn't do anything. As in my above post, read Martins guide and ignore everything else as it either doesn't do anything, or has already been set to the best starting values by Martin.
15k switchpoint
80A current limit
15k switchpoint
80A current limit
Tia, evolution
#2545
With the Speedpassion v3 I run maximum endbell timing, otherwise it's just slow.
With the X11 start with the Speedpassion settings as a safe starting point, and add more fixed timing if the motor temperature is okay. I don't think the X11 will ever be as quick as the SP, so I'd run the SP out of the two.
Neither of these motors have an internal temperature sensor, so it is possible to overheat and damage them if you run too much timing. You definitely need a temperature gun to check the temperature after each run. Keep the SP below 80degC (ideally below 70). Not sure about the X11, but as it only has a bonded rotor I'd think no more than 70degC.
#2546
OK Thanks. I try it the next time i go practice. I always temp the motor and esc after some runs if setting is changed.
Tia, evolution
Tia, evolution
#2547
#2548
Switchpoint question
my understanding is once the motor hits the switchpoint it creates higher boost
Here are the manual switchpoint advice
9,5 -13,5 T -> 8000 U/min - 12500 U/min
6,5 T 17000 U/min
modified > 30000 U/min
and Martins advice
For 10.5/6.5 the switchpoint should be between 15 25000
For Modified 5.5T 25000
4.5T 35000
Does anyone know if these numbers are also to be used for 12th scale or should it be lower due to voltage?
6,5 T 17000 U/min
and Martins advice
4.5T 35000
#2549
6,5 T 17000 U/min
and Martins advice
4.5T 35000
6,5 T 17000 U/min
and Martins advice
4.5T 35000
#2550
hi guys,
i recently bought a gm120 (old version, before 2009)
i have no info about it, i know that esc has version about 3. something.
and new version is 13 i think
i want to send it to the gm for update, how would i do that?
i will run it modified with lrp 4t.
also i will need the software to use with sp v3 10.5
thanks for the tips
thanks for the tips
