GM Brushless
#1531
Think we may have solved the problem with esc going dead before start, Ashley Wiffen has found something about it on the german forum and it translates to this.
On the transmitter tab in the latest sofware you have a neutral point width which is set to 80, reduce this to 50 and it apparently gives a much smaller neutral parameter on the transmitter which helps with radio's with a large dead spot, namely the futaba 3vcs.
You can also nudge the trim forward untill the red light comes on the esc to make sure you dont get any probs.
Cheers Paul
Cheers Paul
#1533
9716x GM-Genius xxx Upgrade V11.6
Not sure if is related Paul - but GM have just posted a firmware update -v11.6
Description: flash all three LEDs in the neutral point, if no Power software is activated.
#1534
I am looking at trying mod and was wondering if i could ask for some advise.
I have a gm120 (not the 2010) and was wondering what setting I should run a mod on (mode 2)?
I will be running a novak ballistic 5.5 motor on a large outdoor circuit on tarmac with a xray t2009. a guide to gearing starting point would also be great aswell.
Thanks in advance
James
Thanks in advance
James
#1535
11.6 software
Ben
#1536
hey Ben, i ran 11.6 this weekend (fri at sidcup) and nothing major from what i can tell, although it did seem to be smoother away from the line (had issues with sensors/cogging before)
#1537
Hi, I have GM Genius 120 #7168 firmware 4.9 (2009) and want to upgrade to the latest firmware. If the difference is large for the new GII, I'd like to update v8.0, I think it's the last for my esc.
There is possibility to update via USB cable. Why does not Gm makes available the software to upgrade.
Nelson
Nelson
The new firmware has mode 9 ??
Someone confirm the address for upgrade?
Graupner GmbH & Co.KG
Service: Update
Henriettenstraße 94-96
73230 Kirchheim unter Teck
Germany
Tel.: 0049 (0)7021/722-0
E-Mail: [email protected] or [email protected]
#1538
Yes correct address. Include 20 Euro for return international postage
#1539
Up loaded 11.6 two times now and reset speedo and still shows 11.1 ?
Ben
#1540
did you do a factory reset after upgrading the speedo ?
If you read it in, what does it say ?
I'll have a look next time i see you if you don't get it sorted
#1541
Cheers Chris, I did a factory reset two times but still shows 11.1 firmware
I will try again from scratch and let you know.
Ben
Ben
#1542
I updated mine and it shows 11.6 on upload, I asked the question at GM about the differences, only change is three flashing led's at neutral if no change is made to power profile and a more stable eeprom, anyone know how the unstability manifested it'self before? Also mine has a tendancy to cog from standstill not from slow corners at all once rolling but always from dead still, anyone know how to correct this?
#1543
What do you have your softstart set at?
#1544
why is everybody messing around with softstart!???
I reckon it's with the Highspeedtiming enabled (reserved4=1)
in that case it starts off in HST mode already, the slight back and forth rocking is normal and you won't get that away
you could enable HST with switchpoint (reseved 4 = 3) but then you have a switchpoint which normally never feels really good.
11.6 runs more stable, issues of the speedo not starting once in launch control have been solved, and when no power program has been enabled, the leds flash in neutral
that's it
I stongly recommend updating!
that's it
#1545
I dont mess around with softstart it was just a suggestion as from the instructions it states ''In case the motor doesn't speed up as desired, or gets stuck at lower RPMs than desired, then immediately switch the motor off and reduce the Softgas value''
