Looking for a special antenna
Re: Looking for a special antenna
Why not just make your own? Take a piece of scrap lexan from a body, servo tape it to your upper deck and wind the antenna around the lexan. It does the job and doesn't cost anything.
I have seen those antennas and I believe Parma made them. You can also bend a regular antenna into this shape with a littel heat and patience. Seen that done may times b4 also.
TRC makes the triangle antenna mount. You use a studdy antenna tube and then mount the TRC triangle on that and wrap your antenna around. I thought it was great when I had it in my TC-3. Stormer Hobbies or Tower shoul have it. You might have to search for Trinity since they own TRC, or just have your LHS call Trinity directly to order or for a part number.
Disaster999
Are you talking about the Kose fiberglass antenna? I run one on one of my F1 cars and it worls great. It seems to be lightweight enough so it doesn't have an impact on performance and has an aluminum tip, so it doesn't get all ground up when you roll. You just wind the antenna wire around it and slide an o-ring over the top to hold the wire in place.
