Xray T2'008
#1336
Need a little favor please.
I have EU spec with the updated pulleys. I'm running the USVTA series and needed a FDR of 4.2-4.3. Well that required a 34 pinion with the stock 84 spur 48 pitch- which doesn't fit.
Does anyone have 100 or 101 64 pitch spur that would post the diameter so I know it this will work without modification.
#1337
100 spur
A 100 t 64p spur with a 40 t 64p pinion and the 1.7 Internal will give you a 4.25 FDR.
Hope that helps,
Darrald
Hope that helps,
Darrald
#1339
I wouldn't say that one is 'better' than the other. I have tried both ways that you are describing, and I preferred the optional top deck. For carpet, rubber, low-to-medium, I would recommend using both the optional top deck AND starting with most chassis flex and go from there...you might also want to try removing the two uppermost screws from your shock tower/bulkhead to get additional flex.
#1341
I do not know the diameter.
A 100 will fit fine and give you the ratio you need if you are running 1.7 internal. If, as you said, you are running updated/upgraded pulley's.
If not and you are at 2.375 internal you will need like a 56 pinion & I have not tried that combo.
Darrald
Darrald
#1343
Darrald
Darrald
#1346
Hi Kev
I use Trakpower 4900 but shrink wrap removed and 2x 0.3 mm shim under topdeck...
fits and works nice
hope that helps
fits and works nice
hope that helps
#1347
Set up question...
I just started using the new Jaco Green wheels. These wheels are taller than RP30s. I had to lower my ride heigth by 1.5 mm to get back down to 5mm. By doing that my car now dives a little more in the corners. That is due to the roll center being raised by the new wheels....correct?
#1348
Set up question...
#1350
guys,is there any news about the next Xray's Touring Car??? T2'009 or T3??? maybe.
on 17th Aug, i'll racing with my T2'007 in carpet track for the first time (foam tyre)....(i always run rubber-asphalt)...what should i change in my asphalt set up????
