New JACO foam sedan tires
#273
Maybe this is why everyone that's drives my car always tells me I have too much steering, no matter the setup. I usually rotate since I use the same tires all around. Guess I need to start swapping Left to Right only, not Front to Rear and Left to Right.
#276
I prefer soap and water. Lather ...rinse...repeat. Don't use any soap with moisturizers. I used to use Dial. It's a little more work, but the tires feel like new when you are done. They dry in no time with a small fan on them.
#279
Regional Moderator
Well I've just about finished my first set of Prisms, and I have to say they're the best foams I've ever run. For some reason, the things just seem to last forever. I ran my original set non-stop (practice and race) for about 5 weekends(including A LOT of running at a big race in Omaha) and they are just now getting to the point where I think I need to replace them.
I've gotten the best results running Magenta all around. This is what most of the Mi3 setups I've seen suggest, and thats what I got the best results with. Running Magenta all around let me rotate the tires constantly to keep the tires equal and avoid trips to the truer, so you gotta love that.
No problems with chunking at all. I had small chunks on the very edges as the tires got really small, after contact with boards/other cars etc..., but nothing that hindered performance.
#280
#282
guys does anyone have any issues with the new prisms rubbing a little in the front of there 007???
#283
Trader Rating: 51 (100%+)
Jack Rimer ygpm question for ya
