mr21 bo1a carb settings
mugen ninja 21 bo1a factory carb settings??
when I owned my ninja, I had this same question because I couldn't tune it properly, so I just swapped it out for an RB carb.
I only did that because No one helped me with the settings. It seemed like it didn't have a good factory set up on it when it left the factory. But I was one of the first people to own one when it came out and no one knew anything about it.
I know I didn't help you any, so I'll stop boring you.
Registered User
LSN = 6 turns out
HSN = 5 turns out
HSN = 5 turns out
What mixture of fuel do you run to get best results from your motor i have played with the carb and dilled your setting in but cant get it to be reliable
2 10 mins races and then the tune starts to get a bit wonky cant put my finger on it
i have been told to run a 25% nitro but i will proberly run 20% with 10% caster and 2% syn
Is this correct or can you shed some more light on to my problems.
I am running it in a LOSI 8
Registered User
hey i am running this im my losi *ight buggy tooo. with an msr 1005 pipe. this baby screams. AND VERRRRRRRRRRRYYYYYYYY FFAAAASSSSSTTTTTT!!!!!!!!!!
Registered User
ALSO I USE THE DYNIMATE QUICK FIRE BOK TOO. IT TRUNS IT OVER WITH A BREEZ
bo1 or bo1a? i thought the bo1a fixed the bearing problem. i'm on my third ninja and have had zero issues with any of them. i sold the other two because i got out of nitro. wish i had kept them! great engines!
I am not dissing this engine, because it definately one of the fastest one out there.... I am just having bad luck with the rear bearing in mine....
