unknown kyosho?
unknown kyosho?
ok guys got a car from a friend im trying to get running. its a 3 belt, two speed, front and rear diffs no spool or one way. carbon fibre front shock tower and top deck blue lower deck with team kyosho engraved lay down steering servo stood up throttle. built in under top deck servo saver has aluminium non threaded shocks with read top caps. a gs 11r or 15r not sure which has a read pull start. has same fuel tank as fw-05t and kyosho inferno tr-15. has friction fit wheel hexes ie no cros pins just push them on. oh the final thing is its c hub suspension. no pivot balls at all also has universals.
any ideas on what it is would be great a manual would be fantastic as i need to set up the throttle linkage.
cheers, ill post picks latter if i dont have any luck.
Does it resemble the older HPI NRS4 or NRS4-2's?
Actually, does it look like this?
If it does, you can set it up exactly like the NRS4/NRS4-2 linkage. HPI even makes a throttle linkage set just for it. The car piactured in the last pic is a GP Spider MKII World Cup Edition.
It sure sounds like an MKII WCE.
Your looking at a ten year old car. This is the only "help" I know on-line for this car, but its just an MKII. Sounds like you have more hop-ups, but it should help.
http://www.hobbyone.com.br/vistaex.asp?kit=31712
