1/12 RS12G Atsushi Hara Replica
#662
QUESTION AH-12
Hello.
I am a boy of SPAIN and wanted hacerte a question if it is not annoyance.
The KIT OF ATSUSHI HARA AH-12 HAMMER. is easy to mount or difficult?
You can say to me that pieces are needed to complete the KIT: ASSO
RC12L4 - ASSO RC12L3 - YOKOMO RC12L4Y.
Indicated the back supports of the motor in the photo, of which car is?
In which it tends I can buy all his kit and pieces? it is urgent
In which it tends it I can buy everything?
Thank you very much.
Greetings.
Greetings.
#663
Originally Posted by TFR
Does anybody know if P-DUB's foam bumper for 1/12th fit the AH12 with those big body post?
I use the Yokomo YRX-12 Shaped Front Foam Bumper
Part #: SP-12LSB
I don't know what P-dub's looks like but the Yokomo bumper is wide and can be trimmed to fit the body but they are hard to get.
#665
grey rear tires full wash
purple front tires 2/3rd wash
front brace
1 degree camber
10 degree Castor
.5mm tow out
.18 front springs
crc light tube lube one the king pings
ae 40 weight shock oil
copper spring
crc light tube lube on the friction disks
1.5mm rear pod drop
46mm role out
hope this helps
chris morrison
front brace
1 degree camber
10 degree Castor
.5mm tow out
.18 front springs
copper spring
1.5mm rear pod drop
46mm role out
hope this helps
chris morrison
#667
Selling my Hammer 12 if anybody is interested...
http://www.rctech.net/forum/showthre...44#post3008244
#668
Looks a lot like the proto Hara used. Cyclone 12.
#670
Originally Posted by Marcos.J
old news!!
#672
Im so sad a friend thew my box away it had my hammer in it.
#673
Barry Wite, Looks like you were a step ahead of HB, the car you built looks alot like it. Where did you have the anodizing done? Was it expensive? I am going to be getting a used RC12L4 or CRC T-Force and I would like to have it anodized. Also do you have to prep the Aluminum at all?
